Cam help please
Hey everyone, my sons and I picked up a project engine that came with a comp cam but the part # is saying custom grind cam. The fellow I bought it from has passed and I’m not sure if he was building this engine for N/A or boost etc. Anyone out there shine a little light on what this cam is and what we will need to go with it , what stall torque converter etc. Any help is much appreciated
Just by googling that its a pretty basic cam, maybe a "truck" grind. Your stall is going to depend on a few things other than cam (gears, car weight, tire). What car is it?
that cam going in a 6.0L, 5.7L, 5.3L?
I think you want a tighter LSA with a boosted engine.
What size motor is it going in? What vehicle? What stall converter will you be using? Depending on engine size you could use that cam with a stock stall, also depends a bit on the stock stall, the newer ones stall up higher than the previous
I would think it would be decent in a 5.3 or 5.7 with a 2600 converter.
You need much better than stock valve springs, and of course you'll have to select the correct length push rods. It should work fine along with stock rockers and all that. It'll benefit HUGELY from headers. Depending on what you're doing it could be a pretty good choice.
I think you'd be happier with a 212°/218° 112° .550" one.
Trade/sell it to a F-body, Vette, or GTO owner.
There's NO SUCH THING as, I'm gonna buy this ONE cam, and it'll work GREAT N/A, and then I'm gonna "slap a turbo on it" and it will work EVEN BETTER. Can't tell you how many people have gone down that fantasy-land path. NEVER works. A cam for N/A has one set of properties, a cam for turbo applications is COMPETELY DIFFERENT. Buy a cam for what you're doing now; when the time comes for the other, buy a cam for that.
Never heard of putting a Frod car rear in a Chevy truck. In terms of, "Crown Vic PI". Frod 9", of course. Not the other. Not saying it can't happen, only, good luck.
