LS1 cam choice with AFR heads
Old Oct 25, 2019 | 02:45 PM
RonSSNova's Avatar
500whp seems generous given that cam has zero overlap and a 90mm setup.
Ok, that’s fine
Old Oct 25, 2019 | 05:10 PM
HQLS1's Avatar
ive been suggested that 227 232 612 595 113+4 would be the smallest id want to go with AFR 210 heads?
Old Oct 25, 2019 | 07:41 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
I like those durations,splits & lifts! alot for the AFR 210s and your goals/combo. A FAST 90/92 with 90/92 TB would be worth 15-25 through
your whole curve 3000-7000 RPM. I would go 115*+3* BUT and its a big BUT LOL, Im over 50 and favor stealth & low speed manners.
112+3,113+4 all splitting hairs.
The AFR cathedrals because of their outstanding flow & E/I relationship need less exhaust split and/or overlap to provide excellent results
along with much better low speed manners and driveability with small to medium cams.
Just dont choke it down with the LS6 Intake any longer than financially necessary.
My .02.
Good Luck
Old Oct 25, 2019 | 07:56 PM
HQLS1's Avatar
yep, probably will go fast 92 combo, i think these cam specs with 112+3 would be the one!!
Old Oct 25, 2019 | 08:31 PM
HQLS1's Avatar
would you mill the heads with this cam?
Old Oct 25, 2019 | 09:08 PM
Darth_V8r's Avatar
Moderator
That is a great compliment to AFR 210 heads. Great midrange.
Old Oct 25, 2019 | 10:22 PM
HQLS1's Avatar
have gone with 227 232 612 595 113+4
next question should i mill the AFR heads? and if so what to?
Old Oct 25, 2019 | 11:31 PM
What gas are you running? Do you know your current CR?
Old Oct 26, 2019 | 05:34 AM
HQLS1's Avatar
no current CR as engine is being built for a conversion to a 70's street car, fuel will be pump gas 95 or 98 octane
Old Oct 26, 2019 | 07:34 AM
Darth_V8r's Avatar
Moderator
11.5 compression. 60cc chambers depending on your deck height. .041 head gaskets. Send it
Old Oct 26, 2019 | 11:31 AM
With that static CR and the suggested cam, should the dynamic CR allow using gas even lower than the 95-98 octane he predicts using?
I hope that doesn't sound too naïve...
Old Oct 26, 2019 | 06:59 PM
  #32
Darth_V8r's Avatar
Moderator
Usually when I see 95 or 98 I presume it is outside the us. Often foreign 98 is about like our 93.
Old Oct 26, 2019 | 07:04 PM
  #33
Launch's Avatar
98 octane is the aussie version of USA 93 octane.
Old Oct 26, 2019 | 07:32 PM
  #34
Gotcha. Thanks to you and Darth!
Old Oct 27, 2019 | 03:03 AM
  #35
HQLS1's Avatar
correct, im form NZ so our octane same as australia
Old Nov 1, 2019 | 12:50 AM
  #36
HQLS1's Avatar
So im nearly all sorted,just waiting on parts to arrive, set up will be
LS1
AFR 210 heads
fast LSX with fast 92mm intake
1 3/4 headers
4.11 diff
manual
227 232 612 595 113 cam
YELLA TERRA 1.7 roller rockers
any suggestions for injector size?
cheers
Old Nov 1, 2019 | 06:52 AM
  #37
Darth_V8r's Avatar
Moderator
LS1
AFR 210 heads
1 3/4 headers
4.11 diff
manual
cheers
42 lb/hr will be plenty
