LS1 cam choice with AFR heads
Old Oct 22, 2019 | 04:11 AM
HQLS1's Avatar
Default LS1 cam choice with AFR heads
Hey,im after some help for a cam selection my set up is
LS1, Ls6 intake, 1 3/4 headers, AFR 210cc heads, mafless, yella terra roller rockers,4.11 gears, 6 speed ,manual. will be tuned after cam. Car is a weekend driver but still looking for ok ecomomy and good idle with good mid power,,anyone with AFR knowledge please give some advise.
Ive narrowed down to
232 234 590 596 110
225 232 578 590 112.5
224 228 580 600 110
Old Oct 22, 2019 | 03:28 PM
Darth_V8r's Avatar
Moderator
Of the three, the 225. But I do not really like any of them
Old Oct 22, 2019 | 03:48 PM
Given his current setup and what he wants out of it, what sort of cam would you advise in this case? I'm just curious.
I'm kinda thinking High Lift Hot Cam, or similar, but I could very well be off base here too.
Old Oct 22, 2019 | 05:08 PM
00pooterSS's Avatar
The summit stage 2 cam would be one to look at. I'm sure if you had someone cut you a custom grind it would look a little different but wouldn't make the car a different animal necessarily. Summit cams are easy on the wallet too.
https://www.summitracing.com/parts/s...make/chevrolet
Old Oct 22, 2019 | 07:20 PM
Darth_V8r's Avatar
Moderator
I would be thinking Titan 4. The AFR 210 heads will help tame the cam. That combo would be explosive in the midrange. My two cents
Old Oct 23, 2019 | 02:55 AM
HQLS1's Avatar
any one had any experience with cam motion, whats the quality like?
Old Oct 23, 2019 | 06:05 AM
Darth_V8r's Avatar
Moderator
Outstanding. I do all my cams through them
Old Oct 23, 2019 | 10:36 AM
00pooterSS's Avatar
There's a few companies that are as good as it gets, Cam Motion is one of them.
Old Oct 23, 2019 | 11:23 AM
ddnspider's Avatar
I would err more towards the tame side. Titan 2, Summit Racing stage 2, etc. Duration in the 22X range, LSA in the 112-114 range for those that like to reference LSA. Overlap <3.
Old Oct 23, 2019 | 12:50 PM
HQLS1's Avatar
im looking at titan 3 or titan 4, just checked out thier website, how to i know what cam shaft core type to order, 3 options ?
Old Oct 23, 2019 | 12:52 PM
ddnspider's Avatar
I went with the standard on my Titan 2. They've done some crazy stuff with the regular core.
Old Oct 23, 2019 | 01:11 PM
LilJayV10's Avatar
Don't the AFR heads favor single pattern cams due to the exhaust flow being so good.
Or am I thinking about something else?
Old Oct 23, 2019 | 01:26 PM
Darth_V8r's Avatar
Moderator
I like to run a bit of split even on AFR heads. Basically open EV a bit early and have some overlap. Helps it carry past peak. ESP with some compression.
For what OP is doing, any cam core is fine.
Old Oct 23, 2019 | 03:33 PM
JakeFusion's Avatar
Super Hulk Smash
The AFR 224/228 114+1 Cam is a good proven option as well...
Old Oct 25, 2019 | 01:13 PM
RonSSNova's Avatar
I have the earlier AFR 205’s on my C5. Milled to 60cc. Stock short block.
Pat G designed me a custom cam through EPS.
598/608 226/230 114+1
Runs very well. I do have FAST intake, 90mm TB etc.
Made 443 on our Dyno Dynamics dyno.
Corrected to Dyno Jet numbers, which Dyno Dynamics calls “Brand X”, it’s right at 500.
Car snuck into the tens once.....
Ron
Old Oct 25, 2019 | 01:25 PM
ddnspider's Avatar
Ron
500whp seems generous given that cam has zero overlap and a 90mm setup.
Old Oct 25, 2019 | 01:43 PM
HQLS1's Avatar
i was looking at the VCM 480
224 228 580 600 110
ls1 is going into a 70's street car so dont mind a bit of lope to the idle
Old Oct 25, 2019 | 02:00 PM
SLP IROC-Z's Avatar
I have a 233/239 .600 .600 113 cam for sale it has a nice lope to it and great power. It would would great with your application and heads. Im going bigger.
Old Oct 25, 2019 | 02:25 PM
HQLS1's Avatar
sounds nice..whats your set up,diff gears,trans etc..what does it drive like around town?
Old Oct 25, 2019 | 02:45 PM
SLP IROC-Z's Avatar
Fast 102/102, 4" coupler, ftp 104mm lid, 243 heads milled to 62cc, johnson 2110 lifters, chromoly pushrods, stock rockers, pac 1207x springs, msd wires, slp 25% underdrive, 1 7/8 long tubes, 3" off road y pipe, borla cat back, 6 speed, 3540lbs, suspension, mwc fab9, 4.30s. 11.36 @ 121 with a 1.64 60', leaving easy. Tuned by me. it drives awesome, some surging under 1800rpm at light load, never really notice it unless im in stop and go traffic on the highway. i havent been able to finish tuning it, i think taking some timing out 1800 at light throttle would minimize it. i daily drove it for 5000 miles just want to go bigger now.
