Help with LQ9 Setup
I was thinking of getting a set of 243s. A lot about cam design has changed over the years since my old "El Toro" predator-z cam was in. Now you don't even see reverse splits anymore.
Can anyone help me recommend a small cam, what CC to mill the heads to, and head gasket thickness? Also, what are optimum levels of static and dynamic compression on pump 91? I found a calculator online but I don't have all the specs.
LQ9
Bore: 4.0
Stroke: 3.622
Cylinder head Chambers: 71cc (317) 64.5 (243)
Piston Dome Dish: 0.00
Head gasket thickness: ?
Head Gasket bore: ?
Deck Clearance: .007
Connecting rod length: 6.098
If I was swapping in a 6.0 into my car, I would look into getting a set of 821 or 823 (LS3/L92) heads with a custom cam. You'll need an intake to match the square port heads.
And here is a nice mild cam from summit
https://www.summitracing.com/parts/sum-8707
What gear and stall?
