Trunion "Upgrade" Failure
EDIT. I forgot but also did summit set in a lq4 with tsp 228/228 110 with beehives, it's been fine with bouncing off the rev limiter for at least 1000 mi now. Something else will die first....
Maybe any instabilities also.
Since the bushings can be initially scraped or superficially damaged on install, thats where some of the glitter comes from but also the oil grooves/recesses will wear in on any surface also and will bed in.
People still wont recognize that bronze bushings are made to wear? Any bronze bushing. Thats and basic self lubrication are 2 of the main qualities of bronze and why its used. Top side oiling can drastically effect wear also. Low oil pressure etc.
The only ones so far that wont wear are the needle bearings, which are plagued with metallurgical failures due to the design, material differences in hardness and smoothness, lack of oiling, or improper install. And our max effort rockers with an open sided full bearing. Those would be the top of the line, no failures, no glitter, no wear option. We will be offering them in a cartridge style soon. Lots to do and little time to do it in. They are a simple press in, easy to lube, and go. I will be checking ls7 rocker fitment soon, but due to the poor ls7 geometry with a stock rocker wearing guides and valves, may not even be offered.
If you look close in between the C-clip tabs you can see the housing is cracked and probably about to fail soon.
if you look close in between the c-clip tabs you can see the housing is cracked and probably about to fail soon.
that is not a comp trunion
i have purchased over 100 set of comp trunions, i have seen a bunch of fakes
first of all the comp trunions are 100% rem polished, and they use small clips,
any trunion with large clips like in the picture are for sure from china not a comp cams trunion
