looking for a truck cam
What engine? What heads? What truck is it going into and what will you be doing with it? What is your budget?
My boxed reply is to look at Summit's offerings for truck cams and pick one that will work in your application.
Plus, as was also said in the other thread, a good tune will really help you.
To repeat- NO CONVERTER NEEDED!! You really need to learn more about how different cams behave.
The 2 cams I mention are less duration than some stock cams, but these have more lift and are optimized for making low end torque while improving power everywhere.
With that mild a cam, you could get by with stock pushrods, but the extra insurance of stronger new ones is a good idea.
If you mill the heads and use the thinner head gasket, it is a good idea to measure for correct pushrod length as said above.
