PRC as cast 225 HCI build thread
Many do run the .040, I've always thought that was borderline tight and not really worth the risk vs reward. I like the idea of the .045 a little more than the .040
I would want dual 3" exh on that car, but the flowmaster dual 3 to single 4 is a great piece and that will be a lot better than running a single 3"
I hear you on the dual 3" exhaust, it's just not in the budget right now. I would want to be able to make it quiet for my neighborhood, but also have cutouts on it. Not even sure how I would accomplish that, but it would definitely require some custom work.
Thanks! I'm dying to see how it does.
Unfortunately there's not many tuning options around here. There are only 2 other shops I know of that have dynos in the area, one handles all the local sand toys, so they have a 3-4 month wait, and I know people who have had experience with the other shop, and none of it has been good.
So I have 2 options if I'm going to move forward with this build:
1. Use a local guy who was taught by my tuner, who I've heard some good things about, but I'm not quite sure how experienced he is. Also I don't think he has access to a dyno right now.
2. Email tune (probably Pat G?) which means I will need to buy HP Tuners.
The HP tuner and Pat G option sounds like a winner.
I think you'll enjoy going the route of buying the hp tuners and being a part of the process and then being able to dabble also.
This afternoon I tuned the IAC (he includes instructions on how to do this), which I really should have done right away, and now the car runs even better. It was having some issues where it seemed to bog at WOT at low RPM, but it seems to have been fixed after doing this. I'm blown away that the tune can be this good with just a list of mods. Now I have to do a bit of data logging and send him the logs so he can revise the tune and really dial it in.
Getting lifters was a nightmare, I had planned on getting Johnson 2110 lifters, but they sold out everywhere just before I tried to buy them. I ended up putting in an order with BTR so that they would ship to me as soon as they're available. While I was waiting, looking everywhere I possibly could to find good lifters, I found out that Tony Mamo had a few sets of Johnson 2116LSR link bar lifters, so I ordered those right way.
So this is the final build
- FTP 104mm lid
- Spectre 4" MAF housing with GM card LS3/LS7 MAF sensor. I'm using the stock IAT in the lid instead of the one in the MAF card
- Nick Williams 102mm throttle body
- FAST LSXR 102 intake manifold, removed the ribs on the bottom side of the runners to open up the inside a little bit, and provide a smoother path for the air to flow
- PRC as cast 225 heads, 62cc combustion chamber, solid stem stainless valves
- Texas Speed polished 0.660 dual spring kit
- Cometic 0.045 headgaskets
- TSP Torquer V2 cam 232/234 112 LSA 0.600/0.600
- Johnson 2116LSR lifters
- Texas Speed 1-7/8 long tube headers
- Flowmaster 4" merge
- 4" cutout
- 3" Magnaflow catback
- Racetronix 255 lph fuel pump
- OEM LS7 injectors part # 0 280 158 051
I'm still debating whether I want to pull the manifold again and try to port match it to the heads, there is a significant lip in the transition between the runners and the ports on the head.
I'm also debating whether or not I should pull my AC condenser and put my Chrs1313 ram air in. The AC doesn't work, but I kinda want to try to get it fixed too lol. I'm not sure where I'll put an oil cooler though if I put the ram air on, and I'll definitely need one if I'm going to do HPDEs.
- FTP 104mm lid
- 4" cutout
