Ls1 228r cam questions
Save your old head gaskets for doing the PTV checking and subtract .007 from your measurements to replicate the .045 gaskets
Can you swing about $500 for 243 heads? If so run those instead of the 241 heads. They are considerably better
Since you have the heads off and old gaskets
Put the cam in and put an old head gasket on it and one of the heads on it and hand tighten a few of your old head bolts in the head. Install the rocker arms and pushrods on one cylinder and spin the engine over with a ratchet on the crank pulley a couple of revolutions. Pull the head and cut the play doh down the middle of the valve impression and measure how thick it is.
In this video they also show cleaning the head bolt holes which is really important to do on your LS. Needs to be done on all LS motors. To do this I take a old head bolt and slot it a few times with a die grinder long ways to make it look the same as a thread tap looks then I run it in and out of the holes several times then spray out with compressed air then I spray brake cleaner in the holes and spray them out again with compressed air
Some say the OE gasket is .051, that's the general accepted measurement, but I've seen some say .053 so subtract .008 I guess to be on the safe side
