No compression... But odd results.
My old 346 build, the heads were aftermarket AFR castings with thicker decks, the lifters were solid, AND the base circle was shorter than yours is. My pushrods were 7.425". The only times I've ever seen longer than that were:
1. Short travel lifters were used, in which case pushrods ended up being 7.7" long
2. Tall deck block
Many of these aftermarket heads are lifetime castings. You may need to redo the valves, etc, but the castings are extremely good. Are you SURE it was a casting failure that caused it to blow up?
The car runs fine which tells me something was way off with your method of doing a leakdown. Glad it's running though.
