Looking for DIY 799 Head Porting Advice
Old Dec 13, 2019 | 12:57 PM
omc8's Avatar
Like Katech , Livernois has a CNC program for $500 but keep in mind this on runners only does not touch the chamber no VJ . You send your cores bare and cleaned .
Old Dec 13, 2019 | 01:14 PM
omc8's Avatar
As for the hand port on 799 is not a good choice for a novice , many of these have a seat overhang can be tricky to blend , the die cast 243 is much better in this aspect .and don't have this problem. I would probably get the best VJ and have them bowl blend and call it a day. If you're still determined to hand port , get cheap set 706 and practice on them first , if you muck them up your only out $50 bucks.
Old Dec 13, 2019 | 03:46 PM
gollum's Avatar
Start at the combustion chamber and unshroud the valves to increase low and mid lift flow numbers. Very easy to do on all LS heads and you will get better results than just port matching and bowl clean up.
Read link :https://myroadnews.com/tuning-techno...-chamber-work/
Old Dec 13, 2019 | 05:22 PM
00pooterSS's Avatar
Originally Posted by gjestico
Problem with those cheaper CNC jobs is they don't include the valve job which can be a large part of the gains. Especially if the head has some miles on it. Look at how the low-lift flow is actually less than stock.
Exactly and there's more power in the valve job and bowl blend in many cases
If I had to choose between porting and bowl blending with a valve job, i'd go for the bowl blend and valve job.
Texas speed does a valve job, back cut on the intake valves, bowl blend, they radius the exhaust valves, cnc port the ports, and I believe they also cnc the chamber. Double check that info but I'm pretty sure they do it all in their port program.
Not knocking the Katech program. $500 is a really nice price, but be aware it's just port work only.
Old Dec 13, 2019 | 07:03 PM
TSP does all you say BUT chamber work. However, any milling needed is included in the $799.99 price.
Old Dec 13, 2019 | 07:12 PM
This exactly. Improved flow all over without losing low lift flow,
Old Dec 13, 2019 | 08:53 PM
SoCalDave's Avatar
The 1st thing I did on my 799 heads was remove the rocker stud boss lump and I saw that on AGearHead4Life Youtube channel. Coming from the SBC days I know how much a set of heads can improve the power production. I'll know what my '01 Camaro can run once Fontana opens up in 2020. Port your heads if you want to learn.
