Cam for a 383 ls1 stroker
I say this because I already have a Big ***** Thumpr cam in the engine and it was a right pain to get dialed in properly and is potentially causing a few other issues to occur.
Is there a list or are there companies which actually list cams to suit 383 strokers?
*edit*
setup is:
383ci LS1 stroker
241 heads with compcam springs/etc
Big ***** thumpr cam
Vic jr manifold
Quickfuel Diamon 750cfm carb
TH400 with 3200 stall
9" rear conversion with 3.7's
A cam for one guy's 383 would be different than another 383 due to different heads/intake combos. That way you get the right cam for the job.
I rang around and was recommended the BTR Stroker 400+ Stage 3 cam by a workshop (they do a lot of stroker builds usually 408+ though) who reckon the slightly less ci won't matter much and will really come alive when I do the heads.
Other 1 that I was recommended was the BTR LS3 stage 4 cam..
So still unsure and as it drags on the rush/urge just isn't as strong... just need to bite the bullet and order 1.
So still unsure and as it drags on the rush/urge just isn't as strong... just need to bite the bullet and order 1.[/QUOTE
This is the cam cam motion recommend it for me I have trickflow 220s and an fast 102 , I ended up going with an blower cam because I’m going with an proCharger this spring
