Leaking head gasket on re-ring job
Thanks
Brian
I've tried to avoid the machine shop but with this motor but that may be and inevitability. If you have to use them you're only saving peanuts over buying one at one of the national vendors.
There are lots of You Tube testimonial videos about these products under long term use. You be the judge . . .
Rick
Thanks for your responses
Brian
As for the notch head? No idea, probably something to do with the casting process there was a few different processes happening for LS motors in the early days
