Stripped harmonic balancer bolt.
Old Jan 5, 2020 | 01:45 PM
bclounch's Avatar
Default Stripped harmonic balancer bolt.
In the middle of my LQ4 rebuild. Pulled the harmonic balancer to find the bolt had stripped. Can I just tap the crank and install the new bolt?
Old Jan 5, 2020 | 06:18 PM
99blkfrc99's Avatar
Na. When you put it back in just add a couple extra uga duga's from the impact.
Old Jan 5, 2020 | 07:01 PM
Alwhite00's Avatar
Did you try to pull the balancer on with the bolt?
Old Jan 5, 2020 | 07:24 PM
bclounch's Avatar
Maybe the shop that initially put this motor in did... Since it only lasted 20k miles I'm going to assume they cut some corners.
Old Jan 6, 2020 | 05:10 PM
00pooterSS's Avatar
Saw this recently, may help ya out
Old Jan 6, 2020 | 05:51 PM
pdxmotorhead's Avatar
Did that bolt bottom out in the crank?? Before it brought the torque up to hold the pulley on?
Old Jan 8, 2020 | 02:28 PM
bclounch's Avatar
I ended up cutting the old bolt into a thread chaser. Was able to get all of the debris out and the threads seem to have not stripped in the crank itself.
Old Jan 22, 2021 | 05:46 PM
302LS1's Avatar
What happened to the motor?
Old Jan 23, 2021 | 01:11 AM
QwkTrip's Avatar
That's not a reusable bolt, you know. You're supposed to use a new one.
Old Jan 25, 2021 | 10:32 AM
LilJayV10's Avatar
Where did he say he reused the old bolt other than turning it into a thread chaser?
Old Jan 25, 2021 | 02:20 PM
Sacrilege's Avatar
That’s not stripped, that’s broken. Either get another crank or have a professional remove that because the chance of you getting that out without damaging the crank is about 0.
Old Jan 25, 2021 | 02:25 PM
Sacrilege's Avatar
This is also why you never buy an engine from a private party, especially not one that is claiming “rebuilt.” I can’t even count how many engines my friends have gone through because they truly believe they’re getting some sort of smoking deal from some random dude. If the engine was good, they wouldn’t be selling it. Buy your engines from junkyards/parts wholesalers. You just want a bone stock, completely untouched engine as a starting point.
Old Jan 25, 2021 | 02:44 PM
This might be my ignorance talking here, but you might try threading (NOT torqueing) a good bolt into the crank to see how deep the good threads are. At least then you will know for sure if a piece is still in there, AND if the threads still feel snug enough to be usable. You never know for sure, until you KNOW....
Just my .02.....
Old Jan 28, 2021 | 08:17 PM
dixiebandit69's Avatar
Really? Because I've reused them A BUNCH of times... Every time, actually. And I've never had a problem. Neither have any of the other guys I work with, and we work on GM trucks every day, for everything imaginable.
If you read a GM service manual for these engines, almost every bolt (even those that see less than 35 lb/ft) are "one time use."
I don't buy that.
Anyway, to the original poster: Despite the information I just gave, get a new bolt (or a used one that isn't damaged! It won't matter!), and make sure that it can thread all the way to the bottom of that hole, WITH THE BALANCER PRESSED ALL THE WAY ON, CORRECTLY. You do have a balancer installation tool, right?
If it doesn't, try your home-made thread cleaner again, a few more times, with plenty of lube, and check it again.
If that doesn't do any good, tell us how much thread-depth you've lost, and we can go from there.
If it's just 3/16" or so, I'd add an extra washer under the bolt, and call it good. If it's 1/4" or more, then something else may need to be done.
It looks like you've still got a lot of threads in there, so I wouldn't worry too much.
Old Jan 28, 2021 | 09:41 PM
QwkTrip's Avatar
Yes, really. The "We do it wrong all the time" argument doesn't change anything.
Old Jan 28, 2021 | 11:47 PM
QwkTrip, you know that I respect you and all of the work you've done, and all of the information you've shared, but I really don't see the point of discarding an undamaged harmonic balancer bolt.
IF the balancer is a "good" fit, it is pressed on (hopefully with the proper tool, or a long piece of threaded rod - all the same to me!), and the torque on the bolt shouldn't really be that big of a deal, AS LONG AS IT IS TIGHT ENOUGH TO NOT LOOSEN DURING OPERATION.
How is a reused bolt (in this application, where there is no chance of any sort of gasket-crush; it's just a metal-on -metal contact) inferior to a new one?
Old Jan 29, 2021 | 01:17 AM
RedXray's Avatar
The bolt is stretched during 140 degrees angle after the initial torque of 37 ft/lbs. That is a lot of tightening and stretching if you've ever installed the crank bolt by the manual. The old bolt is only used to set the balancer against the crankshaft with 240 ft/lb of torque then discarded. New bolt at 37 ft/lbs and 140* degrees.
I actually broke an impact socket tightening by hand when I hit the 140* degree mark. Scared the **** out of me thinking I broke off the crank bolt. After that scare I only use the 12pt ARP bolt that torques to spec instead of angle. The OEM bolt is only $5 so it makes since to change it. Some people hammer in the old bolt with an impact with zero issues and some go by the manual YMMV
Attachment 712263
Attachment 712972
Old Jan 29, 2021 | 04:06 AM
QwkTrip's Avatar
Appreciate you too, bud.
I'm not sure there is any such thing as an undamaged torque-to-yield bolt. I think it is damaged by definition. The bolt is deformed (shape out of spec) and weakened. I don't know all the ramifications of that, but one thing I do know is it won't achieve the same clamping load as the first time.
But basically what you're asking is, How far out of spec can you go before it becomes a problem? In my mind questions like these must have a good reason or else it's a waste of time even talking about it. So first you've got to answer the question, What problem is being solved when somebody refused to follow the standard? The answer is clearly nothing. And re-using the bolt is actually creating a new risk that didn't exist before.
Old Jan 29, 2021 | 02:02 PM
Ls7colorado's Avatar
Old Jan 29, 2021 | 02:30 PM
ddnspider's Avatar
https://en.wikipedia.org/wiki/Torque...ly%20elongated.
