Help testing vacuum leak
I used the search feature and people recommended that to do a vacuum leak test you should spray some carb cleaner around the suspect areas and listen for an increase in RPM.
My question is, what areas then should I test, and will this test be sufficient with the car idling.
Please let me know where I should check (I'm not very familiar with the LS1 PCV system and where intake leaks could occur so please be overly simple with me
Also, could this be a bad pcv valve?thanks!
