5.3 build
Old Jan 10, 2020 | 08:57 PM
Corrieelder89's Avatar
Default 5.3 build
Hello my name is corrie and I’m starting a 5.3 build I’m breaking everything down now to send to the machine shop what’s a good set up to get good horse power and still be a good daily driver wit a mean lope????
Edit
Old Jan 10, 2020 | 09:10 PM
Ls7colorado's Avatar
Edit
Put it all back together, Swap in cam and valve springs... tune.... good exhaust..... done
if something was wrong with it just go grab another one, not worth building when the stock ones work just fine..
Old Jan 10, 2020 | 09:20 PM
what valve springs and cam you recommend? Got 862 heads
Old Jan 10, 2020 | 09:35 PM
What are your goals for the car?
Old Jan 10, 2020 | 10:11 PM
have a pretty good amount of power and a mean sound to it I’m getting it rebuilt and i wanna bored it
Old Jan 10, 2020 | 11:22 PM
Which 5.3 do you have?
Old Jan 11, 2020 | 07:56 AM
I believe a lm7
Old Jan 11, 2020 | 10:26 AM
Don't bore it more than needed to clean up wear.
Just do a good short block rebuild, get a good multiangle valve job on the heads, plus maybe a bowl blend, then put in a cam of around 220/228, about .550 lift, plus springs that will handle the lift.
The engine will be as dependable as stock, sound good, and run well.
Old Jan 11, 2020 | 10:28 AM
Ok thanks for the help imma go with that
Old Jan 12, 2020 | 07:59 PM
https://www.summitracing.com/parts/sum-8707-1
Thats what I would go with for a good budget setup.
and once again i would slap it back together... unless you just WANT to bore it and rebuild it, if thats the case I would have it bored to 3.898 and make it a 5.7. or ditch it and find a 6.0 thats in good shape...
