363 stroker for boost
Old Jan 20, 2020 | 04:34 PM
KT35's Avatar
Default 363 stroker for boost
I'm running about 10 psi using a vortecT3 VI.
I have an L33 block. With a 4.00 stroke forged crank.
The question is:
Do I go 363 or 383?
There are very few options for pistons in the 363. If I do this I'm probably looking at 9.9/10 to 1 on compression.
Also if I do the 363 the cylinder walls keep more thickness. would be a 3.800 bore vice 3.898.
Anyone out there done and 363 for boost?
Also using LS6 243 heads 64cc.
KT
Old Jan 20, 2020 | 04:46 PM
RonSSNova's Avatar
I'll let the experts chime in. I don't recall anyone here doing a stock bore 5.3 stroker.
Ron
Old Jan 20, 2020 | 05:23 PM
Ls7colorado's Avatar
Sounds like an awesome setup for torque, but I just wonder why a stroker?
Obviously since your going boost you can make as much power as you want with the stock stroke and be more reliable?
Old Jan 20, 2020 | 07:08 PM
KT35's Avatar
The big reason for stroker is because I have the crank already. I was going to do 383 in my LS6 block but that is no longer an option as the LS6 block is cracked due to piston failure.
Old Jan 21, 2020 | 05:50 AM
If it were me Id sell the 4" crank, gap the rings on the L33 and drop it in. Especially if your only gonna be running 10PSI.
