Budget 5.3 Build
If you wanted a bigger cam then next up would be our stage 3 truck cam SUM-8713. Specs on it are .545/.545, 222/231, 112+5. This will have a steady lope. Stock springs are not recommended with this cam. We recommend the budget-friendly LS6 springs previously mentioned. This can still be daily driver friendly with 3* of overlap with a good tune and stall converter. You can get away with a stock converter but a 2500+ rpm stall converter is recommended.
We offer either of these camshafts in kits with springs or kits with springs and an install kit. You can view these in the "Related Kit/Combos" tab within the overview of the camshaft.
That's below most stock compression now days.
My current truck is 11.0:1 stock, the 6.2 is 11.5:1
I'd actually try to go closer to 11:1 if this was my build
On the heads, drop them off at a competent performance shop and have a valve job (3-5 angle) done and bowl blend. Possibly mill of a little depending on your compression preference. The valve job and bowl blend costs less than port work and gives you a lot of the power you get from a full blown port job.
Rockers, use stock ones if they are in good shape.
Horsepower... hard to say because of not knowing what trans wheels tires etc but you should be able to get in the mid to upper 300's at the tire pretty easy with a cam and a little bit of head touch up and some compression. That would be with headers good exhaust and a good intake manifold. The LS6 manifold is excellent for saving money since you can keep a stock throttle body on it and easily run a cable drive throttle body. The TBSS truck intake is nice but you have to have an adapter to run a cable drive throttle body since the intake was made for an electronic throttle body. And you'll need a 90 mm throttle body. But the LS6 intake with the 78mm throttle body will still make excellent power here.
You'll also be okay if you just slap on the 706 heads. For a tiny bump in compression you can get the WS6 store gaskets that are .045 thick instead of .051 like the OEM gaskets. You'll get a little better quench which helps prevent detonation, and a bump in compression. Win win situation. Plus they cost the same as OEM. Win win win. However, I'm not positive if they make them for the small bore truck motor. Check with them.
