Is my oil pan cracked
I'm not sure what chunk you see missing unless you're talking about that little piece in the edge, I don't think it's missing it looks like the way it was cast.
Lay a gasket on there and see if it will seal, If it's that little piece on the edge then it's probably outside where the gasket will be anyway.
That is as-cast. Use it.
The following users liked this post:
G Atsma (01-26-2020)
G Atsma (01-27-2020)
