Need inputs on my piston/rod choice
Why does he need a better block? Can you show where an aluminum block is a failure point before anything else? Ive yet to see and block failures because the block was not a cast iron block. I think this is a myth. Richard Holdener proved that too. I better tell my buddy with his 8 second car that he better change blocks, right? lol
It is a daily driver, and will only see over 5K RPMs one a dyno and maybe a few times a year at the drag strip.
Chances are you will still go over 5k rpms by accident when you blow the tires off.
I will be doing something similar but using the stock crank with boost.
Since we are already beyond that point... 1. Is there a reason you are rebuilding the motor. Is it something you feel needs done so might as well put forged rods and pistons in it while you're doing it or is there nothing wrong with it and you are rebuilding it specifically to go forged? 2. Stock crank will be fine either way for a blower at how fast you will need to spin it to make 10 psi on your setup. 3. If it makes financial sense to go ahead and buy a balanced assembly complete and you are going to buy a forged crank anyway then get the 4" stroke and build a 383. More torque in the lower rpm now where you are going to spend all your time mr never goes over 5k rpm...LOL...just giving you a hard time. The stroker definitely isn't needed, but if you do eventually put the 2300 on it you would need even less boost to make the power the 347 would of at 10 psi.
I don't want a 383 stroker. I do not want more stroke than bore. 370 stroker might be an option though.
It's still going to make obnoxious lowend torque.
I just hit 16 psi and 7k about an hour ago.
