Need inputs on my piston/rod choice
Old Mar 2, 2020 | 12:53 PM
  #61
FCar2000TA's Avatar
Veteran: Air Force
That's because you're strictly thinking of the stock Procharger fan stuff that is crap. What many people do is switch to pushers, something like twin Derale 16925's which are fantastic pushers and will keep the car cool and the AC working.
You and your valid reasons for considering other options. :-)
Old Mar 2, 2020 | 01:02 PM
  #62
ddnspider's Avatar
Originally Posted by FCar2000TA
I have a bad case of "if stock comes out, stock should not go back in". So, we will see what a 370 stroker kit ends up costing, and go from there.
I would normally agree, but a stock LS crank is a beast.
Was it I Robot or Eagle Eye? "My logic is undeniable."
Old Mar 2, 2020 | 01:25 PM
  #63
FCar2000TA's Avatar
Veteran: Air Force
I am going to have the rotating assembly balanced either way. If the price difference between rods/pistons/stock crank + balance vs balanced rotating assembly is not more than $500, I don't see the point of keeping the stock crank.
Old Mar 2, 2020 | 01:56 PM
  #64
BCNUL8R's Avatar
Makes sense. Another thing to consider is... How much can you get out of your current short block if you sell it? Cost of balanced rotating assembly + $$$ you get from selling your current short block + cost of machining current block = close to the cost of a built short block with a better block as a starting point?
Old Mar 2, 2020 | 05:04 PM
  #65
FCar2000TA's Avatar
Veteran: Air Force
I got bit right in the head of my dick playing that game. I will not be selling anything until I make a 1/4 mile pass.
Old Mar 2, 2020 | 05:57 PM
  #66
BCNUL8R's Avatar
I just saw a sponsor has a sale on 408 short blocks for $4500. A balanced rotating assembly with all forged internals and bearing is around $2500 machining of the block plus new main bolts or studs $500. Sell current running long block with heads and cam since you have new heads and will be getting a new cam any way $1500. You're most of the way there and that 408 will make over 500 rwhp easy with more torque plus you're built to handle 1000+ rwhp so no matter how crazy you decide to go you are covered.
Just giving you more to think about … LOL
Old Mar 4, 2020 | 04:06 PM
  #67
FCar2000TA's Avatar
Veteran: Air Force
I am not doing a new motor. I have to draw the line somewhere, and that is the block.
Old Mar 4, 2020 | 04:51 PM
  #68
BCNUL8R's Avatar
I can relate on having to draw the line some where. Most of us have some kind of budget limitation. Just throwing out options to consider. Most of the sponsors sell short blocks on the budget side that you couldn't build yourself for that price if you have to pay a local machinist to do anything.
Old Mar 8, 2020 | 05:59 AM
  #69
FCar2000TA's Avatar
Veteran: Air Force
I talked one of the guys that had a Procharger on his C5 vette. He said that he had the upgraded pusher fans, and he still was unable to drive the car during the hot summer months because his AC just couldn't cool in 110+ degree heat.
Old Mar 8, 2020 | 07:19 AM
  #70
Darth_V8r's Avatar
Moderator
Lol. I drew the line at new car
Old Mar 8, 2020 | 07:33 AM
  #71
FCar2000TA's Avatar
Veteran: Air Force
lol. I just don't need a block for what I am doing right now, and I really do not want to get a block unless it is a Darton sleeved 427 shortblock.
Old Mar 8, 2020 | 07:45 AM
  #72
Darth_V8r's Avatar
Moderator
Dayton sleeved 427 is regarded
Old Mar 8, 2020 | 09:04 AM
  #73
ddnspider's Avatar
Did he say which fans? They are not all created equal....and he's in a better, different airflow/temp problems than an Fbody.
