11.0:1 comp with very small cam ???
Old Feb 26, 2020 | 03:09 PM
TimsLS1's Avatar
Default 11.0:1 comp with very small cam ???
Hi Could someone tell me if 11.0:1 SCR compression ok to run in my LS1 with my cam?
Its 216/228, 2.7 overlap .590 lift, 853 heads, currently it will be 10.34:1 SCR but I'd like to run a thinner head gasket to bump it up, I'll run on 98 ron octane which is same as your 93 aki in USA.
If 11.0:1 isn't any good for this cam I'll get a bigger one that is.
Old Feb 26, 2020 | 03:19 PM
SLP IROC-Z's Avatar
i ran an ls6 cam with 243s milled to 62cc and stock gaskets was approx 10.7 it ran great, dont see why you couldnt run 11:1 with your cam.
Old Feb 26, 2020 | 03:31 PM
Pulse Red's Avatar
I ran Higgins ported 241 with 11:1 compression with a comp 214/217 .600/.587 112+4 cam for 10 years. This is on Aussie pump 98. Made just under 400 rwhp through a restrictive exhaust on a few Aussie dyno which read a lot lower than US dynos. So no issues.
Old Feb 26, 2020 | 04:28 PM
Summitracing's Avatar
LS1Tech Sponsor
The ls2 with a very small cam sported 10.9:1
__________________
800-230-3030
www.SummitRacing.com
Old Feb 26, 2020 | 05:15 PM
TimsLS1's Avatar
Ok thanks to all, really appreciate the info.
Regards
Tim
Old Feb 26, 2020 | 08:39 PM
00pooterSS's Avatar
I understand what you're asking, smaller cams usually have higher dynamic compression. But there's so much more to it
To answer your question in a simple way, you have the same compression as an LS2 and an LS2 ran a much smaller cam
It comes down the valve events of that cam. And even then, you can manipulate those through the cam's timing to get it where you want it.
You need to run that specific cam in a dynamic compression calculator... or you can set it to where you have 180-200 ish degrees of cranking compression and should be good.
For the way you're thinking, you could go to a bigger cam, and have more problems than you would with that cam. It isn't the cam size, it's the intake valve closing point really.
Old Feb 26, 2020 | 08:41 PM
00pooterSS's Avatar
One of the most important things that needs to be known is how much advance, if any, is ground into that cam
Old Feb 27, 2020 | 12:43 AM
TimsLS1's Avatar
Thanks for that, it has +2 degrees advance, although it was a custom ground to my specs and they said they would grind it with no advance so it's an oddity to me, I checked and rechecked lots times and phoned them but +2 measures up most accurately with the specs on cam sheet.
Old Feb 27, 2020 | 07:50 AM
Darth_V8r's Avatar
Moderator
If you have the cam card look at your intake valve close. If it is over 40 at 050, you are very safe at 11:1
Old Feb 27, 2020 | 09:05 AM
LilJayV10's Avatar
It's because the dyno's turn backwards down there...
Old Feb 27, 2020 | 10:58 AM
00pooterSS's Avatar
This
Tim what does it show the IVC to be?
Old Feb 27, 2020 | 02:00 PM
TimsLS1's Avatar
Thanks, It shows IVC to be 38.5 ??? I measured it at 37.5 ?
Quote
"I ran Higgins ported 241 with 11:1 compression with a comp 214/217 .600/.587 112+4 cam for 10 years. This is on Aussie pump 98. Made just under 400 rwhp through a restrictive exhaust on a few Aussie dyno which read a lot lower than US dynos. So no issues."
Did you mean to say you verified this on a "few Aussie dynos", that's a lot of power for that duration, I have bit more duration and I am only expecting around 360 to 370 rwhp, in my freshly built LS1 with mildly ported heads in M6. It must be your Higgins heads helping out a lot.
Old Feb 27, 2020 | 02:15 PM
Darth_V8r's Avatar
Moderator
Ok at that you are right at the limit for 93 octane US gasoline at 11.0 compression. If it makes you nervous, a 1 degree retard will get you breathing room and still be very torquey
Old Feb 27, 2020 | 02:31 PM
TimsLS1's Avatar
That's good to know, I can only go 2 degree increments on my timing wheel if I retard from my current +2 possition to 0 to 0 my IVC ends up at 40 which seems much better for what I'm wanting but my EVO ends up being 41.5, is this still ok?
If doing this restricts exhaust side a bit I'm not concerned as I have too much on exhaust side anyway with my wide split and more porting on exhaust?
Old Feb 27, 2020 | 02:36 PM
Pulse Red's Avatar
Quote
"I ran Higgins ported 241 with 11:1 compression with a comp 214/217 .600/.587 112+4 cam for 10 years. This is on Aussie pump 98. Made just under 400 rwhp through a restrictive exhaust on a few Aussie dyno which read a lot lower than US dynos. So no issues.'
Did you mean to say you verified this one a few Aussie dynos, that's a lot of power for that duration, I have bit more duration and I am only expecting around 360 to 370 rwhp, in my freshly built LS1 with mildly ported heads in M6. It must be your Higgins heads helping out a lot.
Yeah, I've heard this a lot. It was run on 3 dyno, all belonging to the most well known LS shops in Sydney (fierce competitors) and made within a few kW of each other.
One run was at a dyno day. Being so quiet (small exhaust, little overlap) it gave people quite the shock when it was reeled off that number and was higher than nearly all the other big cams that day (majority were around 370-380). No one believed it was a baby cam. Even the shop owner running the dyno.
Even a well known cam manufacturer refused to believe the duration based on the power and time at the track and said to get it measured when I replaced it. I did and it was actually smaller than I originally was told (I bought it as a secret shop cam with a duration of 216/220).
It was a great combo and ran very hard on the street but the combo was built on old lobes and things have changed a lot since those days.
Old Feb 27, 2020 | 02:41 PM
TimsLS1's Avatar
Really impressive!!! Higgins knows what he's doing, he knows not to port too much and loose low to mid range he ports too 42 mm on intake, and you were still able to make good top end. There are a few on here who have made 400 rwhp with 216 or less cam in LS1 but not many.Do you remember where peak HP was at?
Old Feb 27, 2020 | 02:53 PM
Pulse Red's Avatar
Really impressive!!! Higgins knows what he's doing, he knows not to port too much and loose low to mid ports too 42 mm on intake, and you still able to make good top end. Do you remember where peak HP was at?
Alas, I don't. I would need to find the old dyno sheets. I don't have that cam any more (went bigger, now running 380 rwhp) so don't have them on hand.
I would be one of those on LS1.com.au, I was quite a prolific poster on there. One of the tuners was another who had good results from a 216/220 back in the day.
I believe the Higgins heads are the key. The man knows his stuff. That and a good tune.
Old Feb 27, 2020 | 03:00 PM
TimsLS1's Avatar
I'm learning slowly it's best to use valve events, I've been looking at lots of LS1 cams lately with 216 intake duration and the IVCs vary from 37.5 to 40 (approx), your cam might have been bit bigger than you thought.
Old Feb 27, 2020 | 03:01 PM
Pulse Red's Avatar
I'm learning slowly it's best to use valve events, I've been looking at lots of LS1 cams lately with 216 intake duration and the IVC vary from 37.5 to 40, your cam might have been bit bigger than you thought.
Nope, it was measured by Cam Tech after it was pulled out to confirm exactly what it was since it was a "secret" shop cam.
Old Feb 27, 2020 | 03:08 PM
Darth_V8r's Avatar
Moderator
Yup. Valve events are everything.
Your 41.5 evo is late but at 11:1, it is not insanely late. Will just not carry power as well past peak.
