L33?
Old Feb 26, 2020 | 06:11 PM
boostedstang's Avatar
Default L33?
I bought a aluminum 5.3 that has been took apart.Trying to see if I got the crank that goes with the block.The block has the knock sensors in the side not the top valley,and the timing cover has a sensor in it to.Looks like the crank sensor still goes behind starter and cam sensor in top valley.It has dimple rods,floating pins,and flat tops.It came with a 24 tooth crank.Is there a way to tell if its the right crank or if I need a 58 tooth?It also came with 799 heads.Thanks for any help
Old Feb 26, 2020 | 06:45 PM
If it has side knock sensors, it is not an L33, unless someone moved them and the original bosses are in the valley.
Old Feb 26, 2020 | 06:48 PM
I dont think its a l33 then.Maybe a lh6?
Old Feb 26, 2020 | 06:51 PM
If it has a 24x crank and the DOD towers in the valley, it IS an LH6
Old Feb 26, 2020 | 07:02 PM
Would it have a place for a sensor on timing cover and valley cover?cause they both have a place for a sensor?
omc8's Avatar
Sorry to tell you don't have a L33 it was a gen 3 and 24x with knock sensor in the valley not the side . If it's aluminum block it's most likely a LH6 or LC9 or LH8 if you know what year and vehicle it came from it would help .
Old Feb 26, 2020 | 07:06 PM
SLP IROC-Z's Avatar
what you have has better rods and pistons than an l33
I dont know what it came out of.Just wanting to build a spare Incase my 6.0 twin turbo goes out on me.
Old Feb 26, 2020 | 07:16 PM
omc8's Avatar
If that is the original crank .it probably 2005 LH6 they were 24x
Old Feb 26, 2020 | 08:14 PM
RonSSNova's Avatar
L33 had gen 4 rods and full float pistons.
Old Feb 26, 2020 | 08:15 PM
what is the hole in the timing cover for if cam sensor goes in back like my 6.0?And can I reuse my harness from my Holley hp I have on my 6.0?And is a LH6 good for boost or just use the iron 5.3 I have?
Old Feb 26, 2020 | 08:26 PM
RonSSNova's Avatar
In your photo, there is no cam sensor hole in the back. Thats a true gen 4 block, hence the cam sensor in the front cover.
So is your 6.0 24X? Knock sensors in the valley?
The Holley will accommodate either. Or a combination.
Old Feb 26, 2020 | 08:48 PM
I see what you are talking about now.What is this sensor for?And could it have a 24 tooth being a gen 4? Yeah my 6.0 is a gen 3 with twin turbo and Holley hp.Sorry all the questions Im still learning
Old Feb 26, 2020 | 08:54 PM
Thats a DOD cover.
Old Feb 26, 2020 | 08:58 PM
So I can use the 24 tooth and front cam sensor to swap out with my gen 3 6.0 Holley hp harness?just delete the dod and change cam?
Old Feb 27, 2020 | 08:28 AM
Jays_SSZ28's Avatar
It depends on what your engine controller requires.
24x with a 2x timing gear. Or 58x with 4x timing gear.
Old Feb 27, 2020 | 08:29 AM
AwesomeAuto's Avatar
You can mix and match with an aftermarket ECU.
Old Feb 27, 2020 | 11:54 AM
SLOW SEDAN's Avatar
Holley does require "custom" ignition settings for 58/2x or 24/4x instead of the default drop downs but its easy to setup. You will also have to change 5v vs 12v for the 58 vs 24x sensors but again easy to run a couple wires. I've swapped back and forth on my setups for whatever engine/crank/cam setup is available with Holley and it runs great either way.
Old Feb 27, 2020 | 12:53 PM
Good to know.it was a little confusing cause I bought it done apart,but he said it was the crank that came in the motor.Didnt want to build it then have to change my harness to use it.Also it has 799 heads but I got a set of 317 with it and other iron 5.3,should I use the 799 heads or 317 heads?On my 6.0 I have 317 heads and twin 62mm Pte turbos
Old Feb 27, 2020 | 01:30 PM
SLOW SEDAN's Avatar
Personally I would use the 799.
