Broken Pistons
Old Mar 6, 2020 | 11:56 PM
392killaWs6's Avatar
Originally Posted by G Atsma
^^^^^^^This^^^^^^^
High pressure, not high volume.
Only reason I call it that is bc part number is m295hv
Old Mar 8, 2020 | 08:19 AM
SLP IROC-Z's Avatar
Id skip the 36# injectors and go to ls3/ls7 42# injectors. I say this because my last setup (cam only ls6) would run about 75% DC at 6500 and over 80% after 7000. This is with a 340 racetronix pump, 62-63 psi fuel pressure and ls3/ls7 injectors. Just dont want to see you run out of injector and burn it down again.
Old Mar 8, 2020 | 02:11 PM
Thanks for the advice,
yea I won’t be seeing those RPM
most will be 6100..did you run a fuel pressure regulator??
