243 heads
Old Mar 12, 2020 | 10:38 AM
todds76's Avatar
Default 243 heads
This is my first post had a question about a lq4 that I'm putting together. It has the stock bottom end and I'm installing a stage 4 BTR cam and have a set of cnc ported 243 heads. The question is should I have the heads milled a little to bump the compression ? Sorry if this is a stupid question but I'm new to the LS engines.
Old Mar 12, 2020 | 10:40 AM
SLP IROC-Z's Avatar
Check your piston to valve clearance and mill if you can
Old Mar 15, 2020 | 11:34 AM
senicalj4579's Avatar
Depends on how much you have left on the head material and your clearance. If you do mill them keep in mind you may want to leave some meat there for a future rebuild.
Old Mar 16, 2020 | 08:48 AM
todds76's Avatar
cam specs are dur. 235 242 valve lift .620, .593, lobe sep. 111.0
Old Mar 16, 2020 | 08:50 AM
todds76's Avatar
Thanks for the replies I will check the valve clearance and go from there.
