Engine removal
Old Jul 23, 2004 | 01:31 PM
Tech's Avatar
I'll appreciate the write up as well. Going to be doing this in the next week.
Thanks!
tech@fastlouis.com
Old Jul 23, 2004 | 02:12 PM
texada's Avatar
Originally Posted by 1999_SS_M6
I made a write up for this procedure a long time ago. I detailed step by step on taking it out the bottom with a lift, or with a large frame floor jack. PM me an email addy and I'll send you the MS Word file. I'd be happy to email it if you think it would help.
I agree though, taking it out the bottom is really slick, and you don't have to worry about banging it around or breaking anything. The first two times I did a swap, I did this procedure by myself, with no help guiding or aligning the k-memeber as I lowered the car.... try doing it from the top using a cherry picker by yourself. lol
I need it to reginaldtexada@bellsouth.net
Old Jul 23, 2004 | 10:47 PM
jerflash's Avatar
i need to take my motor out also
i have the heads off already so it sould be easy to take it out the top right?
thanks
Old Jul 23, 2004 | 11:31 PM
Oldtexan's Avatar
I've done it from the bottom on a lift. It's a no brainer really. I had no write ups to go on, just kinda looked at everything and it was pretty obvious what needed to be done. Once you start wrenching you see it's not a big deal. Go for it. Taking it out from the top would suck compared to going from the bottom.
Old Jul 24, 2004 | 06:33 AM
redbandit98's Avatar
it will come out with the heads on,pulley on,intake off and tranny still attatched out the top..just did it.
Old Jul 24, 2004 | 08:29 AM
Cerebrex's Avatar
Is it hard with the heads still on? What's easier? Dropping in a shortblock and assembling the heads inside the car, or just throwing it in already assembled? Thanks for the help. Oh, you guys might want to PM that guy with your email address because I revived this thread...
Old Jul 24, 2004 | 09:09 AM
Thunder175's Avatar
When you pull the motor out from the top, do you take the transmission out with it? If you don't, do you have to brace or otherwise support it from the underside of the car?
Old Jul 24, 2004 | 09:41 AM
jerflash's Avatar
im looking for the easiest wazy to pull it outs possible
my heads are already off and if i pull my trans off it sould be pretty easy right
Old Jul 24, 2004 | 09:52 AM
mike m's Avatar
Jerflash it is pretty easy, you just need to get your bellhousing and flywheel off. Also take off your crank pulley it helps to pull the motor straight out. Make sure you get the ground wires off the side of the block(by the engine mount). take the A/C unit and altenator off too. radiatior has to be out too. have fun.
Old Jul 24, 2004 | 12:51 PM
Cerebrex's Avatar
so do the heads need to come off or not? How hard is it to disassemble or reassemble heads inside the bay?
Old Jul 24, 2004 | 12:56 PM
no,the heads do not have to come off..i will be reinstalling them before i put my motor in. It will go in with no probelm,plus you can be sure that you correctly torque the heads down and in sequence without worrying about trying to get a torque wrench in the engine bay..i also will reinstall my pulley, first,but you can however you want.
matt
Old Jul 24, 2004 | 01:08 PM
  #32
Cerebrex's Avatar
the crank pully might be a problem... let us know how it goes!
Old Jul 24, 2004 | 08:52 PM
  #33
rodent's Avatar
I must be slow... took me and a friend the whole day to pull it from the bottom with air tools. I used a engine hoist and lifted the front with the STB. Rear tires have to be on ramps. I have 31" jackstands that are now holding up the car.
There is so much you have to disconnect.
The engine/trans/kmember rested on a HD funiture dolly and rolled out sideways.
I'm doing a new BMR kmember and struts so this made the most sense.
Old Jul 24, 2004 | 11:11 PM
  #34
awesomeame's Avatar
i too would like a copy.. 2002camaro@sympatico.ca thanks!
--matt
Old Mar 22, 2005 | 08:44 AM
  #35
yobabiesdaddy2001's Avatar
Default Would like the write up
I would like a copy also "yobabiesdaddy2001@yahoo.com"
Old Mar 22, 2005 | 11:13 AM
  #36
LS666's Avatar
anther copy please and thankyou . . .mmccance27@gmail.com
Old Mar 22, 2005 | 04:34 PM
  #37
Mike's 99's Avatar
Take a look at this book "How to Build High-Performance Chevy LS1/LS6 V-8S" by Will Handzel. He is the program manager for GM Performance Parts. Chapter 4 is dedicated to engine removal for F-bodies, Corvettes, and pick-ups. I got a copy from Cartec on the net. The F-bodiesand Corvettes both come out from the bottom. The process does not look to bad, although the lifts look expensive, especially if you are not going to do this on a weekly basis. Good luck
Old Mar 22, 2005 | 09:38 PM
  #38
Jimm's Avatar
Does it include how to remove from the bottom?
Old Mar 23, 2005 | 07:28 AM
  #39
v8maro's Avatar
I've read many many many posts on this and I am going to take it out the bottom. Need an engine stand, cherry picker, and furniture dolly.
-Steve
Old Mar 23, 2005 | 07:37 AM
  #40
hourang's Avatar
i see many ppl want copies of this. you should post it up somewhere and just put a link. if you want i can throw it on my site real quick. if not send me a copy anyway, hourang@yahoo.com
