Roller Rocker Arm opinions...
My neighbor's GMC (5.3L) has a lifter knock until it warms up. It sounds like a classic high-mileage LS lifter knock/tapping sound. I'm trying to get him set-up with new lifters and springs, but I figured we might as well swap the rocker arms as well. I just don't want any fitment issues. That's why I was leaning towards the Scorpion rockers. They seem to clear stock valve covers.
I have even considered swapping my stock rocker arms out for a set of 1.8 Scorpion full roller rockers. My high-er lift cam is not as forgiving on the valve train as the stock cam. I'm sure the roller tips would help to ease any side-loading with the cam's max .600" lift. With 1.8 rockers, my max lift would be .660". I have .660" lift BTR springs, so they should hold...
I'd pick an appropriate aftermarket cam and valve spring kit and get a new set of stock rockers.
I was a little concerned about the reliability of aluminum rocker arms. I see that I'm not the only one. I do think there is some benefit to an increased ratio, especially with a smaller or stock cam. Having the valve open further should allow more air flow, no matter the duration.
You could run a Ti retainer with an aluminum rocker and offset around half of the added weight that the spring will see from the rocker. The question you have to ask here is what are you trying to achieve? Roller rockers will add weight at the valve vs. an Oem steel rocker, there’s no question. Added weight...even 5-6 grams...will cost you rpm which is power, by sending the valve into float a few hundred rpm sooner. You offset the added weight by adding valve spring.
With cam profiles that have high lift, say .650” and up (debatable subject, I know) the roller rockers become necessary due to the Oem stamped steel rocker simply running out of pad, and severely side loading the valve, which causes increased guide and stem wear. But with cam profiles such as this, more duration is always present, which requires more valvespring, so typically the heavier rocker arm is taken into account when selecting springs.
Reliability will always be compromised when using an aluminum roller rocker arm. But aftermarket springs rated higher than Oem springs for a performance camshaft will rarely last as long as the Oem springs will have, as well. Any time there’s an upgrade regarding performance, to any part of an engine, there’s always going to be trade-offs and compromises made to other components, either in the engine itself, or the transmission connected to it, and possibly even the rear end.
Material selection is important regarding upgrades. There are different offerings of materials regarding performance rocker arms. You can purchase roller rockers made of different grades of steel, but the steel units are heavier than their aluminum counterpart, which requires even more spring, which is harder on valve seats and valves. More spring requires stronger pushrods, etc, hence the trade-offs. Ti valves come into the equation eventually regarding valvetrain weight, which further compromises the setup due to the lifespan of Ti being much shorter than steel. We are constantly chasing our tails in the pursuit of power. At the end of the day, Oem rockers are suitable for most builds, unless it’s a max-effort type.
My point was simply that adding lash caps will give you a larger deck on top of the valves to address the issue of running out of surface area at the valve tip
