Rod bolt torque
Old Apr 5, 2020 | 10:47 AM
Novapat67's Avatar
Default Rod bolt torque
I did some searching and found specs for connecting rod bolts with 1 or 2 dots, but what about three? The inside of my 2006 L33 looked pretty sludgy so I pulled a connecting rod cap to check the bearings. Fortunately, they look great. When I went to put it back together, I noticed the rod bolts have three dots instead of one or two. I can't seem to find any torque specs for rod bolts the three dots.?
Here is a pic:
https://imgur.com/a/HouB96m
Old Apr 5, 2020 | 02:41 PM
Here is a pic:
The rod bolts are torque-to-angle. However, I’ve spent a considerable amount of time duplicating this value with a digital torque wrench and found that 45 to 48 ft. Lbs. works great. Two or three dot bolts. I’ve never messed with the one dot bolts. Forget the angle. Torque to 47 ft lbs and send it. You’ll want to do this in two steps. Go to 30 ft lbs and then finish with second step of 47 ft lbs total.
Old Apr 5, 2020 | 07:48 PM
SLP IROC-Z's Avatar
15ft lbs and 85 degrees
