L33 to LQ9 swap
Old Apr 16, 2020 | 11:36 AM
cadben49's Avatar
Default L33 to LQ9 swap
Hello, I am new to forums and am hoping I posted this in the right thread. If not I apologize in advance. But I have a 2005 Silverado 1500 Z71 with the L33 from the factory. I managed to pick up a LQ9 with 110,000 miles for a really good price so I am going to swap it out. I heard it was mostly plug and play except for a flexplate and maybe oil sending unit, is there anything else that I would need to do? And I cant seem to find the right flexplate, do any of you guys know of a specific one that would work? Thankyou very much, I appreciate the help
Old Apr 16, 2020 | 12:07 PM
RB04Av's Avatar
If the LQ9 is from around the same age as your truck, it's COMPLETELY plug & play. Flex plate and OPSU included AFAIK.
Z71 is irrelevant to the engine. It's only skid plates and shocks in your year. That's it; I don't even think they were changing springs or sway bars. Oh and of course GINORMOUS STICKERZZZZZZZ!!!!! Same as my 04 Av.
You'll need a tune.
Old Apr 16, 2020 | 04:47 PM
dixiebandit69's Avatar
Originally Posted by RB04Av
Z71 is irrelevant to the engine. It's only skid plates and shocks in your year...
You'll need a tune.
L33 was only offered in Z71 Silverados, so yes, it is relevant to the engine.
And to the original poster, you don't NEED a tune, but you won't be getting the most out of the engine without one.
Also, why don't you take the 799 heads off of your L33 and put them on the LQ9?
The ports and valves are the same, but the 799s have a smaller chamber, giving you a boost in compression; that's what I'd do.
(If you do that, DEFINITELY GET A TUNE. It will be a significant jump in compression, and you don't want to blow it up.)
Old Apr 16, 2020 | 05:41 PM
cadben49's Avatar
I didnt even think about salvaging the heads, and Im glad that you mentioned that. and I plan on getting and edge CTS tuner and taking it to a local tuner regardless. Ill have to take a good look at them first because one of the big issues with my L33 is a random multiple misfire and slight ticking noise that wasnt fixed by plugs, coil packs, or wires which makes me think it may be some kind of valve issue. But even so I could probably just polish it and drop some new valves in. This thing will be my daily but some nice reliable power is what Im looking for, Ive got a full custom exhaust setup for it too. True dual Borla ATAK 2.5 cratemufflers with an x pipe. Havent seen that setup on any other trucks Like mine so Im curious to see how itll sound on a 6.0.
Old Apr 16, 2020 | 05:47 PM
cadben49's Avatar
You'll need a tune.
Skid plates, shocks, and locking differential which is kinda a big deal for off road capability. Plus the L33 was only offered In specifically extended cab z71s for 2005-2006. But I do appreciate the response, I guess I just received false information when I heard the LQ9 required an SS flexplate to bolt up correctly to a 4l60e. Saves me money
Old Apr 16, 2020 | 06:17 PM
RB04Av's Avatar
Some 6.0 motors - not sure about the LQ9 specifically - were different in the earlier years. LQ4s definitely. Before 02 or some such, not sure the exact year, there was a different length crank, which of course affected the flex plate or flywheel. Later however they abolished that.
Looking for good ways to get rid of my Gov-Bomb... someday...
Old Apr 16, 2020 | 06:33 PM
cadben49's Avatar
Ah I see, the LQ9 is out of a 2005 Escalade which is the same year as mine so sounds like this is about as simple as it gets for an engine swap. Im excited to see where this goes, might end up throwing my 799 heads on it and a nice truck cam. Not sure if 11:1 will work well on pump gas as this is my daily and I believe thats roughly the compression itll put out with that, be one hell of a DD
Old Apr 16, 2020 | 07:21 PM
LQ9 is already 10:1. You want more than that?
Old Apr 16, 2020 | 07:35 PM
cadben49's Avatar
not exactly, but feels like a waste to let a good set of 799 heads go.
Old Apr 16, 2020 | 08:31 PM
68Formula's Avatar
It'd be fine, but you'd have to run it strictly on premium. Even the stock LQ9 recommended premium, but would run on 87 (with reduced performance and fuel economy). On the plus side, the extra compression should increase the efficiency to make up for the added cost of fuel so the $/mile would be a wash (just don't look at the bill). And you'd have even better performance.
While you're adding heads and a tune, might as well upgrade with a baby cam. Something with an intake duration/lift of 204-206/.550-.560 and intake centerline of 110-112 would really compliment the extra head flow and compression.
Old Apr 16, 2020 | 09:08 PM
cadben49's Avatar
I was looking into some stage 1 206 cams, would probably swap that in there before I put the motor in. God knows Ill regret not putting a cam in it down the line after I have it all tucked away in the engine bay. I have heard several people say you cant run 11:1 reliably on 93 but I dont see why not, nothing a nice dyno tune cant fix. My stock 4l60e will be begging me to stop everytime I get on it.
Old Apr 16, 2020 | 09:14 PM
11:1 and 93 go together like peanut butter and jelly. I run 93 with 12.42:1 and its fine.
