Cam plate retainer and tfs adapter
Old May 18, 2020 | 05:19 AM
ldr's Avatar
ldr
Default Cam plate retainer and tfs adapter
Ok. I’m installing my cam got the retainer plate and the trick flow damper plate. Instead of using the supplied bolts can I use my factory hex heads? They are same length.
Old May 18, 2020 | 08:15 AM
Ls7colorado's Avatar
Why would you not wanna use the supplied bolts? For the retainer plate or the chain damper?
The newer style retainer plates use a different style bolt head.
Old May 18, 2020 | 08:55 AM
Bob570's Avatar
I used the button head allen bolts that came with the TFS damper plate, it was strange, neither metric or standard allen keys fit well and I ended up rounding it out when I torqued it down. I would definitely go with hex bolts next time if there is enough clearance.
Old May 18, 2020 | 09:08 AM
Darth_V8r's Avatar
Moderator
https://ls1tech.com/forums/generatio...l#post20182726
Here's why... I had to drill 3 out of the four bolts out of the block
Old May 18, 2020 | 01:14 PM
Wow! glad I havent had that problem. I do hate Allen heads though
Old May 19, 2020 | 07:20 AM
Darth_V8r's Avatar
Moderator
It's funny, reading that post. I was so happy I didn't have to pull the block, and I ended up pulling the block anyway.
Old May 21, 2020 | 12:37 AM
ldr's Avatar
ldr
thanks i went a head and used the oe with loctite. the sizes where identical.
Old May 21, 2020 | 11:31 PM
Redbull87's Avatar
I just got a new cam plate also that came with the torx bolts. I have my oem bolts, should i just reuse the oe bolts and torque to spec.I dont want to run into an issue where I need to try to extract another bolt for the block.
