Lm7 build
Old May 23, 2020 | 02:40 PM
eduardo nevarez's Avatar
Default Lm7 build
So i just pulled my lm7 and planned on just swapping it out with a junkyard one for a daily but decided to rebuild it and try to get 400-450hp out of it looking for advice on where to start this will be my first time rebuilding an engine
Old May 23, 2020 | 05:49 PM
If doing a full rebuild, get the flat top pistons used in the 4.8. They bolt right in. You will then have 10.47:1 compression with no other changes. Get a mild truck cam as I suspect this is a truck engine. You don't want to lose too much low end torque.
Old May 23, 2020 | 05:52 PM
HappySalesman's Avatar
crank power or power at the wheels? 450 at the crank and 450 at the wheels are two very different builds. What kind of application is this going into?
Old May 23, 2020 | 09:40 PM
how much hp gain will I get with these changes also will I have to change transmission to a 4l80e and yes it will be going in a silverado appreciate the help
Old May 23, 2020 | 09:42 PM
at the wheels 450 would be nice but ill settle for 400 and it will be going into a 2000 silverado
Old May 23, 2020 | 09:50 PM
Tuskyz28's Avatar
http://www.trucktrend.com/how-to/eng...s-mild-to-wild
Hope this helps
Old May 23, 2020 | 09:58 PM
thank you so much
Old May 23, 2020 | 10:01 PM
Tuskyz28's Avatar
Originally Posted by eduardo nevarez
thank you so much
You welcome
Old May 25, 2020 | 10:36 PM
400 at the wheels is going to take a lot more than just a piston swap. 450rwhp is going to take a lot, if it's even possible. 400 rwhp is doable, but will take a full-on heads, cam, intake, but I get the feeling that you're going to lose a lot of low-end grunt (at least, compared to what you have now), which doesn't bode well for a truck. What kind of budget are you working on?
Old May 25, 2020 | 10:56 PM
I’m starting with a 2k budget would a small turbo be possible?
Old May 26, 2020 | 05:33 AM
Ls7colorado's Avatar
2k budget you better leave the engine alone and save some more money... You could possibly throw a turbo kit together for that kinda money if you wait around for some deals to come up on used stuff. On a completely stock 5.3 (other than fuel system) you could get 450rwhp with less than 10lbs of boost .
