Chain timing dampeners
Old Jun 10, 2020 | 08:58 AM
Metalchipper's Avatar
Default Chain timing dampeners
Hello,
I am rebuilding my old 2002 Piston Slapping --Lifters Ticking -- but other that sound 5.3 LM7.
Bigger is better pistons, bearings, a good Cloyes timing set----
So my question is,
Do I need a Timing chain dampener? It did not come with one [ No predrilled bolt holes] and the MELLINGBD410DBRKT with comes with mixed reviews.
I would rather drill and tap the block if----1. I need a dampener and 2. could find out where to drill. Unless eyeballing the location is good enough.
Your thoughts and comments please. Thanks
Old Jun 10, 2020 | 09:36 AM
RB04Av's Avatar
You don't "need" it, but it's a good thing to add.
http://www.improvedracing.com/timing...670-p-263.html
I'd recommend drilling the holes rather than the one that goes to the cam retainer bolts. Eyeballing is accurate enough as far as I can tell. Locate it properly, mark with a punch.
Old Jun 10, 2020 | 10:58 AM
99Silver6.0's Avatar
Since I have been piling up parts for a cam swap Ive also been researching these. Ive cammed a few 5.3's over the years and never installed a damper. General consensus I found while searching was its great for manual cars that get auto-crossed. I dont think I am going to mess with putting one in my A4 LS1 when I swap cams/chains.
Old Jun 10, 2020 | 03:05 PM
Default Thanks
Thanks RB04AV and 99Silver6.0,
Looks like it is a Definite Maybe.
I can see where there is rapid RPM changes that would cause the chain slack to vibrate out and in where a dampener would help.
I will think it over some more.
Old Jun 10, 2020 | 04:57 PM
sjsingle1's Avatar
the LS2 and LS1dampners are not the same....so watch out
Old Jun 10, 2020 | 08:03 PM
Default Yup
OK thanks.
Old Jun 10, 2020 | 08:13 PM
Thanks for the link, good price.
