Max effort must haves
Old Jun 23, 2020 | 07:52 PM
Cwarta's Avatar
Default Max effort must haves
Hey guys, nearing the final stages of my 14:1 ps1 build for my nova. Just curious if I’m missing anything that would help me out.
25% UDP
holkey split race intake
4 barrel TB
custom grind cam
heads are as good as I can afford
Don’t see where rockers would benefit
the only thing I can think of is a vacuum pump, which I’m looking into. Any other Bolton stuff that would be advantageous I’m missing?
Old Jun 23, 2020 | 08:02 PM
Jtm2085's Avatar
2in headers? Crank scraper?
Old Jun 23, 2020 | 08:08 PM
jlangley's Avatar
Electric water pump
Old Jun 23, 2020 | 08:12 PM
big hammer's Avatar
EWP and short belt with no tensioner
polished gears
oxygenated fuel
ram air
Old Jun 23, 2020 | 08:13 PM
Your gonna turn some rpm with that setup. What oil pump and pan are you using? What pushrods? Forgive me if you posted in other thread.
Old Jun 23, 2020 | 08:27 PM
Cwarta's Avatar
Ive got 1 7/8 and yes I do have a crank scraper
Originally Posted by jlangley
Electric water pump
Thats the one thing I don’t want. Or at least for now
polished gears
oxygenated fuel
ram air
ill look into that
ive got an aftermarket steel pan, holds like 8 quarts at the full line. No bypass, ported dod oil pump with pressure controlled externally. Haven’t ordered pushrods yet but I’ll by stepping up from the normal 5/16 stuff
Old Jun 23, 2020 | 08:37 PM
ill look into that
If you can fit them run a 3/8” .095 wall pushrod. Manton will make them for you and turn them around crazy quick.
Old Jun 23, 2020 | 09:32 PM
sxc Z28's Avatar
Only because you brought it up...billet rocker arm pedestal stands can be had for $100 and I would do that at a minimum if you’re going to use stock rockers on said build. Goes without saying trunnions.
Old Jun 23, 2020 | 09:34 PM
Darth_V8r's Avatar
Moderator
Cf driveshaft
Old Jun 23, 2020 | 10:34 PM
wannafbody's Avatar
Lightweight clutch and flywheel
Old Jun 23, 2020 | 11:55 PM
NSFW's Avatar
Dry sump or vacuum pump.
Old Jun 24, 2020 | 05:47 AM
99 Black Bird T/A's Avatar
Max effort high rpm build - I'd look into this.
Balanced Camshaft
One of the big time cam guru's Mike Jones likes to make sure the cam & timing sets are balanced etc. I think it helps with reduced valve train harmonics etc.
C5R timing set & C5R chain
3/8 push rods for sure
With the high rpm, for the UD I'd want an ATI 25 percent
And of course what the others listed.
Old Jun 24, 2020 | 12:26 PM
Cwarta's Avatar
How much is really to be gained from the lexan scoops that go through your hood?
Old Jun 25, 2020 | 10:30 PM
vw1320's Avatar
Max effort is max effort but I wonder if you have any data to quantify gains from short belt and no tensioner? Every little bit counts I agree just wondering how much that might be worth.
Old Jun 30, 2020 | 01:55 AM
Lsbmer's Avatar
At the rpm you want. I think this one of those cases where a set of heads will add some serious power.
Old Jun 30, 2020 | 04:31 AM
Launch's Avatar
I think a 4500 TB would gain on what you are doing. The 4150tb's are not that large. I saw a test which seemed fairly legit, 11hp gain on the dyno on a high 600's hp LS going from a fast 1375cfm TB, to a 4500 TB with adapter on the same 4150 single plane intake. Might even gain more in the car under acceleration. 1/4 mile run isn't a dyno test. Dyno is just a tool, can't always measure how the car responds in the real world in a WOT run.
Every little bit helps. Possibly another 1 tenth from ewp/short belt mod. I think i recall years ago the SAM team dropped 2 whole tenths from going ewp and no pwr steer and short belt mod on one of their cars.
Then there's a vacuum pump, which would have to gain at the rpm you will be turning.
Also, 1 7/8 headers in my experience need 3.5 collectors, not 3". Then you can taper down from there to suit what the car likes. Try it with and without some 12" long 3.5" extensions.
Index the spark plugs is another one.
Old Jun 30, 2020 | 04:56 AM
sxc Z28's Avatar
freeing power is more important than adding power. Probably worth 5-10rw all said and done but rev much better
Old Jun 30, 2020 | 10:18 AM
ASRoff's Avatar
electric powersteering.
Old Jul 1, 2020 | 07:19 PM
wannafbody's Avatar
Open headers
Old Jul 1, 2020 | 08:51 PM
Tuskyz28's Avatar
It's not all about power..... Afcos
