Checking for vacuum and exhaust leaks with a smoke machine
Old Jul 25, 2020 | 06:24 AM
showdog75's Avatar
Default Checking for vacuum and exhaust leaks with a smoke machine
I'm curious as to others experience using a smoke machine to check for leaks. I recently bought a cheap smoke machine to check for exhaust leaks but I got to wondering will it affect the O² sensors? It says to use medical grade mineral oil.
Old Jul 25, 2020 | 09:22 AM
bigbomber5's Avatar
I've thought of trying this to see if I have an exhaust leak anywhere. This is a video by Chrisfix on youtube
Old Jul 25, 2020 | 09:27 PM
Z28SteveA4's Avatar
It shouldn’t hurt the o2s at all. Literally smoke exhaust systems every week at work. I usually take an o2 out and start annoying it from there. I try to seal everything up pretty good from where I smoke it and the tail pipe. I usually use a rubber glove on the tail pipe. Hopefully this helps some
Old Jul 26, 2020 | 08:02 AM
showdog75's Avatar
I was going to put the smoke in the tailpipe. That should show any leaks throughout the system all the way to the headers.
Old Jul 26, 2020 | 08:09 AM
Barn Find CETA's Avatar
If smoking out your exhaust doesn’t work, you can then move forward and make a short horror film, or a 80’s music video. Put that smoke cannon to good use. Lol. 😄😄😅😅
Old Jul 27, 2020 | 07:08 AM
gagliano7's Avatar
I have done it to find an intake leak. Found it within seconds of using the smoke. Works great and fast.
