Cam not ground exactly right??
Old Aug 13, 2020 | 11:23 AM
85Iroc's Avatar
Default Cam not ground exactly right??
Got my custom cam installed but it wasn't ground exactly as designed.
Is it common for the cam grinder to get the ICL off by 3 degrees? The cam is on a 111 LSA and supposed to have 3 degrees advance ground in, for a 108 ICL. I measured several times and it was coming in on a 111.5-112 ICL. Put a 3 degree adjustment bushing in and it came out to 108.75-109 ICL
Just curious if that is a common occurrence. Never had one off that far I don't think. Glad I degreed it.
Old Aug 13, 2020 | 01:18 PM
00pooterSS's Avatar
It does happen. Most don't break out a degree wheel and so most don't even see it. I say that because I bet you see 1-2 degrees off on pretty much everything.
Also it could be the chain, or gears, or cam or a combination. Very likely to be a combo of things causing it, that's called stacked tolerances
Old Aug 13, 2020 | 05:50 PM
1FastBrick's Avatar
It all depends on how its ground. Some times they forget to put the advance in. But they are supposed to check it when it's done and supply a matching cam card.
Old Aug 13, 2020 | 08:37 PM
wannafbody's Avatar
Who ground the cam?
Old Aug 13, 2020 | 09:15 PM
KCS's Avatar
KCS
Moderator
In my experience, it’s usually the timing set thats off.
Old Aug 14, 2020 | 08:10 AM
85Iroc's Avatar
Update*
I'm an idiot. Embarrassing to even admit this but.... I guess I'm so used to degreeing SBC, I used the second lifter to degree it. Which is the #1 intake on a SBC, but obviously the exhaust on an LS. Sooo i took everything back apart after I realized my mistake (drilled out cam gear and put advance bushings in and everything to get it "right"), put the zero degree bushing in, and it cam in at 108 ICL, EXACTLY like it was supposed to be. Cam was ground perfectly, by Lunati.
Moral of the story, don't be an idiot.
Old Aug 14, 2020 | 01:23 PM
00pooterSS's Avatar
LOL happens to the best of us man. Glad you got it sorted out.
