PRC heads a TDmachine ls1,6 rocker arms questions
I have a set of PRC 15 degree 64cc heads coming this week. I was gifted a set of comp cams roller rockers from my dad. When i called them to get some install info they sent me to TD machine. TD said i could not use them, and texas speed said I could use them. Any one have any experience with these products or maybe this set up? If i cant use them ill get some yella terras, is it worth getting the 1.8 ratio arms. And lastly anyone have any idea what push rods i would need to just use the checker then order?
set up info
ls1 bottom end
prc heads
ws6 spec cam
0.047 head gasket
i think thats all that needed but ask away if some other info will help
Thanks
set up info
ls1 bottom end
prc heads
ws6 spec cam
0.047 head gasket
Thanks
I thought PRC castings were 13*? I'd call them and ask em. about the rocker recommendation
