Need help..several issues
Old Aug 24, 2020 | 07:26 AM
prot68's Avatar
Default Need help..several issues
Swapping a 2005 lq4 into a project..started and running for a minute raw oil enters exhaust ports of headers at cyl 4 and 6 as well as mist somewhere onto intake manifold. Compression at both cyl was 160-170...150k motor....so replaced valve stem seals..rockers, springs, pushrods all cleaned up..some sludge present. Engine came out of a fleet vehicle..replaced pickup tube o ring, but doesnt seem to oil real well at valve cover...no knocking or abnormal noises and engine otherwise has no fluid leaks..any thoughts??
Old Aug 27, 2020 | 06:54 PM
jetech's Avatar
Veteran: Air Force
What are the compression readings of the other cylinders? Was the throttle wide open or closed during the compression test? Maybe perform a cylinder leakdown check. That will tell you much more about the health of the engine than a standard compression test.
Old Aug 27, 2020 | 08:27 PM
prot68's Avatar
The other cylinders average 175/190. I plan on getting a proper leak down gauge tomorrow.. Just curious when I injected air into the cylinders to assist changing valve stem seals, I could hear the air 'traveling' thru the head. Is that normal? Or should the valves essentially seal to the head? The leak down will give me some numbers although not sure I know how to interpret readings. Compression test throttle was closed. Appreciate any input...motor has absolutely no leaks or weird sounds otherwise...hoping worst case here is remove heads for cleaning/valve job.
Old Aug 27, 2020 | 09:15 PM
jetech's Avatar
Veteran: Air Force
If the cylinder you were working on was at tdc, the valves should have been seated and sealing. So no you shouldn't have heard the sound of air flowing through the head. Read up on performing the leak down test. It is simple and the results are easy to understand.
Cylinder at tdc apply air pressure, read result. If tester shows leakage, listen for air at exhaust (leaking exhaust valve/seat.) Listen at intake( leaking intake valve/seat.) Listen at crankcase breather(leaky rings/worn cylinder.)
Old Aug 27, 2020 | 09:26 PM
jetech's Avatar
Veteran: Air Force
If you find the heads need work, I'd consider swapping to some 706 or 862 casting heads.
Find a Richard Goldener video on YouTube
The 6.0l rematch-stock 706 vs 799 head test
Old Aug 28, 2020 | 10:19 PM
Find a Richard Holdener video on YouTube
Fixed Richard's last name....
Old Aug 29, 2020 | 06:05 AM
jetech's Avatar
Veteran: Air Force
Many apologies to Richard !
Thanks G !
Old Aug 30, 2020 | 09:50 PM
prot68's Avatar
Performed leakdown test..all cup were well within 10-15% of applied psi....except for 2 ironically on the drivers side which I wasn't having problems with?. As when I performed the previous compression test, air could easily be heard traveling thru the heads and particularly at the air filter. I did notice some air release if I removed the oil fill cap and/dipstick...At 150k miles and with good cranking compression and the mostly positive results of the leakdown....What are the odds the heads simply need gone thru? I replaced valve stem seals on one head but could the valve be so carboned up to not seat?
Old Sep 20, 2020 | 03:35 PM
jetech's Avatar
Veteran: Air Force
It is certainly possible the heads could need a servicing, I picked up a set of 243 heads from a GTO with lower mileage. I sent them to TEA for their cnc porting and they replaced 5 worn valve guides .
