Dropped summit pro LS piston on floor....
Old Nov 9, 2020 | 07:49 PM
WE TODD DID's Avatar
I never use the spiral lock tool. I use my thumb. It’s sore for a day or two, but I’m not using the tool.
I shove a spiral lock up under a cuticle at least once per set.
Old Nov 9, 2020 | 08:17 PM
That's gotta feel REEEAAL good.....
Old Nov 10, 2020 | 01:44 PM
Summitracing's Avatar
LS1Tech Sponsor
As others have said, Grind it and send it as long as it's not an "outie". You could run a straight edge up the lands if you wanted. The very top of the top ring land is .054 in. smaller than the bore due to expansion.
__________________
800-230-3030
www.SummitRacing.com
