Spark plug choices 🤔
https://www.texas-speed.com/p-100-ng...park-plug.aspx
as for thermostat, up to you. I keep stock temp thermostats in my junk but my junk gets driven daily and needs hot heat and I want the engine to fully warm up. With a toy a 160, 190, or stock 195 will all work fine.
They are identical except for the gap that is pre set on the plug. I personally usually set the tr55 at .040 on a stock or heads cam setup and never knew the tr5 comes out of the box at .039, the tr55 comes out of the box at .059 so the tr5 is actually closer to correct out of the box, but you can gap either to what you want.
Good call on the tr5 lilvjay10, and I learned something new today.
Another tip to OP: Gap every plug yourself (don't trust out-of-box) and always buy more than 8, in case you drop one, like I do, in the process.
Will have to monitor knock and if there's an issue go to 6's. But with a fairly mild setup and not high compression a 5 is likely fine. But every setup can be a little different.
Also be just fine to start off with 6's
As to platinum tips, I prefer single platinums over double since they run cooler. The AP 5243s have platinum anodes and regular ground straps. The anodes are also focus pointed and thinner than the standard 5243, more like an Iridium plug. If you need a racing plug, than check out AR 94s which are cut back and not really for street use.
NGK is a big name on this forum, but I have never used them. But I can tell you this, I never had a problem with Autolite plugs and all my motors run smooth and strong. Hope this helps.
NGK has had the least come backs in the shop out of all the brands I have used. I have seen 1 bad NGK out of thousands of plug changes.
I have fixed issues I have personally had with other brands of plugs by putting in NGK's
And NGK's are the absolute go to spark plug for big name tuners, racers, import or domestic. There's a reason why. Before I built LS stuff I did turbo and nitrous honda stuff.
NGK the world lol
That all being said, most big name spark plug brands are going to work just fine though and I've had fairly good luck from all brands if you look at the total I've installed versus issues I have had, they're all good these days. But do watch out for knock off's they are out there. Buy from reputable companies and the prices seem extra low, they're fake plugs.
But a few years ago NGK, like Accel before it, started selling V groove plugs with purported performance benefits. I am not saying they are bad plugs, but the V groove is a marketing strategy and doesn't really boost performance. That being said, try a few different brands until you find the one you like the best.
