Bearing Clearances Question and Help Needed
Old Nov 21, 2020 | 06:41 PM
Mark460's Avatar
Default Bearing Clearances Question and Help Needed
I'm working a completely stock 02 LS 5.3 build. I bought a standard size set of Clevite P-series main bearings, I'm measuring about .0028 in. bearing clearance on the mains. I could get some MS-2199H-1 .001 under which would put the clearance closer to factory spec, but the bearings are about $170, don't know if its worth it or maybe different brand bearing. Any recommendations for those you know these engines well?
Old Nov 21, 2020 | 08:44 PM
WE TODD DID's Avatar
Run .0028 all day long
Old Nov 21, 2020 | 09:59 PM
KCS's Avatar
KCS
Moderator
I agree, .0028” would be fine but if you really want to get it tighter, you can look into having the bearings coated. I just had a set coated by Polydyne here in Houston. They can add .0005” to .0007” thickness onto each shell.
