Lq4 build
so, I have a 1970 Monte Carlo, I have a 2004 lq4 317 heads bone stock right now, 4l80e for a trans and 12 bolt 243 rear gears with a posi.
i want to try and get as much out of this as I can safely, so what can I do, other than a cam swap, iam looking at an ls6 intake, other than that, what’s everyone’s thoughts, I will be beating on this thing
thanks, Chris
What gears? Converter? Exhaust? I can't honestly believe you'd leave the 2.43s in it?
converter anything between 3-3500 2.5 header back exhaust, most likely shorty speed engineering headers
How much money you got?? That will determine how much you can get out of it...
If money isnt a problem then the sky is the limit.... everyone has a budget so
Best bang for the buck would be
$3000-4000
flat top pistons
L92/Ls3 topend
so something like the summit 8707 cam
Pushrods and valvesprings
your looking at 500+Hp at the flywheel Cost will depend on how patient you are on getting good deals but
run a good 3600+ stall and enjoy!
Otherwise the sky is the limit, 408 stroker, aftermarket heads, fast intake, ect ect ect ect.... at that point you could just buy a aluminum 427 from texas speed....
$3000-4000
flat top pistons
L92/Ls3 topend
Even with the dish pistons if I remember right you will be about 10:4-1 compression witch is good enough for any decent street motor.
$3000-4000
flat top pistons
L92/Ls3 topend
G Atsma, is 10.07:1 still a decent street compression?
For the stall I would love to get everyone’s opinion, like I said, it will be street driven but I would like to be able to hit the highway for car meets/cruises, so I’d like to be able to cruise decently
And I recalculated it comes out around 10.1:1 with stock .051 head gasket, you can use the WS6 store gaskets witch are .045 and get a small bump to around 10.25:1 (not exact)
anyways Its still decent for a street motor, the flat tops will get you about 11:1 though....
what head gasket should I run?
what trunion kit do you recommend?
i was quoted by BTR stage 4 truck cam and their beehive springs, will the push rods from a 5.3 (where the heads came from) work? Or should I stick with my lq4 push rods?
what lifters to run?
what stall converter to run
Q- Which trunnion kit do you recommend? A- CHE
Q- Will the push rods from a 5.3 (where the heads came from) work? A- All stock 5.3 and LQ4 pushrods are the same
Q- Which stall converter to run? A- Where is your power band?
CHE Precision Trunnion Kit
Most run the LS7 lifters or the Morel 6504
"Baseline" pushrod length without machine work, stock head gasket thickness, camshaft less than .600" lift is 7.4" That said it's always best to measure. If the used pushrods are 7.4" and can be had for a good price that may be a good option. New pushrods (non custom) run about $100 a set. If you buy new Summit ships with a free shipping return label if you need to return for a different length, unused of course.
