possible trunnion upgrade problem
Old Feb 1, 2021 | 03:46 PM
Bosshog's Avatar
Default possible trunnion upgrade problem
So over this last weekend I swapped in the trunnions from btr with c clip style. 2 out of the 16 rockers almost feel "bumpy" ? if that makes any sense. I used a small press from harbor freight, watched to make sure anything lined up directly, i didn't force anything in, bushings has the lettering on the outside, NONE of the needles fell out but after I put the c clip retainers on the ends of the rockers and I started to move the rocker around the trunnion it felt bumpy. there's no drag whatsoever they move freely but have the slightest bumpy feel to them. i dont know if "bumpy" is the right word to use here but yeah hope someone gets what im saying. any suggestions? should I just run them and see what happens ? its a boosted 6.0 with a custom cam shifting at 7k. the other 14 rockers feel smooth.
Old Feb 1, 2021 | 04:12 PM
I would call BTR about this and relate to them exactly what you said here.
Actually that should have been your first move...
Old Feb 1, 2021 | 04:14 PM
Bosshog's Avatar
That's the plan but getting some info from people that have ran into this problem before would be just as good imo.
Old Feb 1, 2021 | 06:47 PM
RedXray's Avatar
They sell individual replacement bearings for their TK kits for $2 each.
I would press those two rockers back apart, inspect then replace if necessary.
Old Feb 1, 2021 | 06:54 PM
RonSSNova's Avatar
Mine were fine. But you never know.
was your work area clean?
Old Feb 1, 2021 | 07:00 PM
Bosshog's Avatar
yeah i cleaned the hell out of the rockers after i removed the old bearings.
Old Feb 1, 2021 | 07:01 PM
Bosshog's Avatar
its almost as if the inside of the trunnion is getting caught up with one of the needles as it spins. not sure though it may clear up after a few break in miles who knows.
Old Feb 1, 2021 | 07:07 PM
Just to be safe, I would replace the affected bearings. Cheap insurance....
 Michael S. Palmer
Old Feb 1, 2021 | 10:27 PM
RonSSNova's Avatar
I’d remove the clips and washers and hose with brake clean and see if they free up.
They gave me s bunch of spare clips, washers and one spare bearing. I thought that was cool.
