How to tell the difference between gen 3 and 4 lq4 crank.
I understand they are both the same part number but are balanced differently. I purchased a 24x reluctor wheel crank that the person said came out of a 2005 that had gen 4 rods and pistons. I know there were some 24x lq4's with gen 4 rods and pistons but is there any way to confirm it?
I have gen 4 rods and lq9 pistons going in a budget build and would rather not have to balance.
Thank you.
Thank you.
Get it balanced anyway.
I would get it balanced, because you change pistons. Not sure about piston weight difference between LQ4 and LQ9, being LQ9s are flat top there is a chance they are heavier?
