Measuring PR Length for Johnson 2116LSR
Old Feb 22, 2021 | 03:05 PM
SCJW's Avatar
Default Measuring PR Length for Johnson 2116LSR
I know this has been covered, but can't find the exact answers I'm looking for. Help me understand the best process with a solid lifter without squeezing the new head gasket and removing again. Is there a way to measure them using the hydraulic lifter? Am I safe to bolt the head down and still reuse the gasket?
Old Feb 22, 2021 | 05:25 PM
Floorman279's Avatar
ive been told you can fully torque a head down and as long as it hasnt really been heat cycled you are a ok on the head side of things. as far as gasket, i seen somewhere to use washers that are the thickness of the torqued down. with new hydraulic lifters, you can measure for proper length with the lifters in the block, even on a johnson lifter where you have a .010 preload range you have to hit. the only thing you wont be able to do is get a wipe pattern to help confirm your pushrod length is ideal.....this is where the solid lifter really comes into play.
Old Feb 22, 2021 | 07:30 PM
jhshnh's Avatar
I used washers that were the same thickness of my head gasket when torqued. I did the same for check PTV clearance. No need in taking a chance on your head gasket when a few cheap washers will work.
Old Feb 22, 2021 | 07:42 PM
SCJW's Avatar
Thanks for the replies. I didn’t even think about using washers. Another idea I had was to use the old gasket which is supposedly .051” compressed. Would it be safe to assume that the gasket thickness is close enough to advertised thickness that I could use the old one and add .004” to the measurement to get the .055” of the new gasket, or is that risky?
Old Feb 23, 2021 | 04:05 AM
gagliano7's Avatar
If you have an old head gasket you can measure the thickness. I measured a used one and it did measure .051 compressed.
Old Feb 23, 2021 | 02:55 PM
SCJW's Avatar
I’ll measure it. I was worried more about the new gasket’s compressed thickness matching the specs. Thanks
Old Feb 23, 2021 | 03:02 PM
WE TODD DID's Avatar
Do you have adjustable valvetrain?
Old Feb 23, 2021 | 04:27 PM
SCJW's Avatar
I haven’t ordered rockers yet, but planned to go with non-adjustable.
Old Feb 23, 2021 | 05:17 PM
BigBlackCamaro's Avatar
Once you bolt the heads down why do you have to take them back off? I don't understand. Just assemble it, measure for pushrods.
Old Feb 23, 2021 | 05:40 PM
SCJW's Avatar
I was thinking the heads needed to be bolted down and pushrods measured and swipe pattern confirmed with a solid lifter before installing the hydraulic lifters.
Old Feb 23, 2021 | 06:15 PM
Why are you using a solid lifter to measure pushrod length then?
Old Feb 23, 2021 | 06:27 PM
Not correct. With stock pedestal mount rockers, there is no swipe pattern adjustment. The rocker geometry/relation to valve and pushrod never changes by adjustment. These get bolted down and thats it.
It is an old (easier) way to check pushrod length by using a solid lifter, but not on an LS engine (in my opinion, due to the non adjustable rockers and varying lifter plunger depths between every available type of lifter) .
You need an adjustable pushrod, and preferable (but optional) 10" caliper.
You just put the adjustable pushrod in and be very careful to not push the lifter plunger down. And on these you'll end up taking the adj pushrod out several times to get it accurate and exactly at zero lash. Then you add the desired lifter preload to the measured pushrod length. And thats the pushrod length needed.
I'm not going to offend you by covering the steps to get it on the base circle, but I'll mention it because someone else probably will if I don't.
Old Feb 23, 2021 | 06:29 PM
It's an old school way to ensure the plunger doesn't get depressed. It it said that these will be used for checking before the hydraulic lifters are installed.
Old Feb 23, 2021 | 06:30 PM
SCJW's Avatar
Can you explain to me why I shouldn’t?
I guess I’m a little confused. I was thinking I needed to use a solid lifter to take preload out of the equation when checking length and then just add the .035 preload to the measurement.
It seems like it would compress the lifter as I turn the motor to check the wipe pattern on the valve.
How would you do it? Thanks again!
Old Feb 23, 2021 | 06:34 PM
If you insist, use a checking spring with a pumped up hydraulic lifter.
Old Feb 23, 2021 | 06:37 PM
SCJW's Avatar
Exactly the answer I was looking for, thank you! I would surely check with the lifter on the cam base circle, but don’t worry about hurting my feelings. I’m here to learn.
One more question: I’ve read that some have to shim the rocker stand up. When would this be necessary?
Old Feb 23, 2021 | 06:39 PM
01CamaroSSTx's Avatar
Finding zero lash can be done using the EOIC method with a hydraulic lifter, a caliper gauge and the COMP CAMS adjustable PR length checking tool.
Old Feb 23, 2021 | 06:42 PM
SCJW's Avatar
I bought an adjustable pushrod checker and 8” caliper last week. I hope the 8” opens enough.
Old Feb 23, 2021 | 06:43 PM
No, that must have been something old because people might have done that at one time. Thats something thats done on a small block ford pedestal mount rocker.
Stock rockers with less than .630 or so lift need to be bolted right to the rocker stand and head. No adjustment is needed.
People using OEM lifters will take them apart to make a solid lifter for measuring PR length. I assume OP is trying to figure out how to go about this with an aftermarket lifter.
