L33 cam
Old Feb 23, 2021 | 11:49 PM
smitty64life's Avatar
Default L33 cam
Sorry if it has been address before but from my search I have no be able to the info I need.
I have a l33 with 243 heads with a Muncie m21 4 speed that with be going in my 77 Celica. The car will be a drift/ track car that will rarely see street use. I got a good deal on a small cam combo but don’t know if it’s too small for my application. My rpm range will be from around 3000-7000 rpms with most of its time at the higher revs. Im also thinking of milling the heads. Is it worth the compression ratio or can I just use a different cam to make the power. Cam specs are below. Any help would be awesome. Thanks
int 222
exh 228
lift. .567
lobe113
https://www.summitracing.com/parts/lun-20540711
Old Feb 24, 2021 | 12:22 AM
You might give Lunati a call to see what they say about it.
