Ported trickflow 220 heads
Old Feb 24, 2021 | 06:27 AM
Rickys2003svt.cobra's Avatar
Default Ported trickflow 220 heads
I’m looking to change up my set up on my proCharged trans am , looking to build an iron 370 with brute speed blower cam and looking to send my tfs 220s to be Cnc ported , who can I send the heads to be ported I’m planning on upgrading my D1sc to an d1x or f1a also
Old Feb 24, 2021 | 08:18 PM
low2001gmc's Avatar
MASS seller approved
With 370 cubes I would consider rectangle port heads due to bigger valves and increased flow. Could probably get some CNC for less than what you could sell your nice cathedral heads. And if you ever went to more cubes, I think you would already have better heads with the rectangle ports.
Old Feb 25, 2021 | 09:01 PM
Bob570's Avatar
I'm pretty sure TEA ports those.
Old Feb 27, 2021 | 11:43 PM
wannafbody's Avatar
If you have an engine with a 3.9 inch bore the LS3 heads won't fit unless they are small bore versions.
Old Feb 28, 2021 | 06:22 AM
mintws6's Avatar
Brian Tooley did mine. Is there much benefit to porting heads on a FI setup? Surely one just turns the boost up a click??
Old Feb 28, 2021 | 12:44 PM
wannafbody's Avatar
Porting stock castings, yes but diminishing returns with aftermarket heads that flow well.
Old Feb 28, 2021 | 01:00 PM
ddnspider's Avatar
Whatever gains you make NA are magnified under boost.
