At what RPM would you recommend shifting at?
i always shift higher than the power peak, the rpm drop will then be closer to the power peak, where the engine is making more power.....helping acceleration. I assumed most people knew this.
I'd stick with the 3:42 gear unless it's a dedicated strip car.
What is intended use, race weight, and tire size to determine rear gear?
For example, our motors max torque starts at 5800 rpm and carries with very little drop to 6200 rpm. Being our rpm only drops 1000 rpm on the shift we shift 1-2 at 6800 which is the beginning of our max Hp. Then we do the 2-3 shift at 7400 rpm so it drops back to 6400 rpm. Right in the middle between the top of peak torque and just before peak Hp which is only a few Hp less than peak. We run an electric shift solenoid so shifts are dead on. This is how we achieve our best 60ft, MPH, and ET's.
Since no one hardly races 1/4 mile anymore and being you have no power adder. Concentrate on the 1/8th, that is what most races are anymore on the street and the track. I would go to the 4.30's if your running 28" tires or a 3.90 if they are 26's. If its a track mostly car, then 4.10's on 28's or 3.73's on 26's if its a street mostly car. The 4L60 has a lower first gear so that will help. At full weight you have to get it out of the hole to get your 60ft down. Then you have to get it to the ground without spinning. If you can't data log, put a camera on the tach so you can see how much it drops on the shift. Then look at your numbers sheet from the dyno and shift it accordingly. If you ever do use a power adder, the more power you through at it the more loose the converter will become so you have to adjust everything accordingly.
