Mystery Sealing Washer (Solved)
I'm swapping the heads and cam on my 2004 LS1 GTO. I also decided to replace the timing chain and oil pump which meant dropping the oil pan.
I've been bagging and tagging all the fasteners so I know how to get it back together again. However I found this sealng washer on the floor near the front of the engine.
I have no idea where it belongs. At first I thought it fit between the oil pump and the block as you can see it's a perfect size, but all instructions on internet say there's nothing there.
Anyone have any ideas ?
looks like one for the ac hoses?
Oil pan drain plug gasket?
That's an A/C gasket. For sure.
It did not come from inside your engine, unless someone fucked up royally in the past.
The following 2 users liked this post by dixiebandit69:
G Atsma (03-10-2021), Jay Fisher (03-10-2021)
