Does my LQ9 build sound solid?
Old Mar 17, 2021 | 09:51 AM
68Formula's Avatar
Originally Posted by G Atsma
VVT and DOD/AFM engines use high volume pumps and the same oil pans as "normal" engines, and are never in danger of sucking the pan dry.
That is true. But those GENIVs also have an oiling circuit that is more longer and complex with high volume-needs because of those features. So not necessarily applicable.
Old Mar 17, 2021 | 11:04 AM
cam's Avatar
cam
Ive had plenty of pooched rockers but its in the pushrod cup or the rocker tip that has been damaged. The trunions have all been good. Yeah the 5.3 gaining value up to or above a 6.0L is laughable.
Old Mar 17, 2021 | 11:11 AM
Fact remains that it STILL pumps a higher volume of oil, which does NOT suck the pan dry.
You're speaking of the downstream side, where the concern is the intake side.
