Does my LQ9 build sound solid?
Also if the Lq9 really only has 150K on it there is NO WAY I would be tearing it apart if it came from a running vehicle and looks clean inside.
People just seem to think they need to have it rebuilt so its new, when in fact the shortblock will outlast the truck.
Converter is Circle D 245mm 3400 stall.
Love the way it drives.
https://www.youtube.com/watch?v=e56aj7GImaM
My 120,000 LQ9 was fairly clean looking inside.
The Truck it was going in I've garage kept the last 19 years and I keep it as clean as possible interior, exterior and under the hood. I wanted the LQ9 to match the cleanliness of the truck inside and out. Pull the dipstick on a "used" engine and clean oil gets brownish pretty fast. I did a simple rebuild rings, bearings, oil pump etc. Runs strong to the 7000 RPM limiter.
The HV & HP pumps are designed for wider engine bearing clearances. Both the HV & HP pumps have longer drive and idler shafts for better support than the standard M295. I've read the f-body guys sometimes overfill to 7 quarts to ensure the hv pumps don't drain the sump. With the camshaft (you listed above) peak RPM's ... I can't see see a mild build sucking the truck pan empty with the HV or HP pump.
Anyways some info there for ya maybe helps a bit. Good luck
gen3 5.3's are getting too high to not just go ahead and get a 6.0
Although I have replaced an gen4 5.3 in a tahoe that had a rocker arm falure with about 200K on the clock all stock.... go figure It was on cylinder 1 so I duno if the DOD had anything to do with it or not..
