Oil Pan Pickup O-ring
Old Mar 31, 2021 | 03:56 PM
Collin King's Avatar
Default Oil Pan Pickup O-ring
I Installed a 302-2 Holley oil pan around a month ago and the pickup tube came with a thin brown o ring. I tried all day to press it in but it never budged. My engine is a LQ9 crate motor with LS3 heads. I took the stock o ring which was the thick red one, it slid right in with some pressure like how a O ring should be. Now I’m a little nervous wondering if it will hold or not. I heard that you shouldn’t mix them as one pickup tube has a indent and one doesn’t. I have no idea now as it is in the engine. I primed my engine with the starter and I have a consistent 35 psi in oil pressure. Anyone think I should drop the pan again and try to switch back to a thinner o ring before I put this in the car? Or should I be fine since I have ok oil pressure at the moment?
Old Mar 31, 2021 | 06:23 PM
Which tube is it? Groove around it or straight walls? Straight (no groove) walls get the thin one, grooved tube gets the fat one.
Old Mar 31, 2021 | 06:42 PM
Thats the problem, I don’t know. I’m 98 percent sure it’s going to be straight walls because it did come with the thin o ring. I’ve also heard of people using the fat o ring on straight walls because it was actually a tighter fit. The stock one came with a fat o ring and that’s the one I used. The stock one has grooved walls
Old Mar 31, 2021 | 07:41 PM
Then WHAT did you take all day trying to press in?? I assumed you were talking about the tube/O-ring assembly.
Old Mar 31, 2021 | 08:06 PM
I am talking about that. I “tried” all day to press in the assembly but the thin o ring would not allow it. I tried the red one it and it slid right in. I think the one that came with the tube was a faulty o ring so I ordered some new ones and now I have to drain oil and drop pan again but better doing it now then later. It’s just one of those things that will keep me paranoid at night so that’s why I want to change it out for the correct o ring. I should of done this during installation but I was being lazy at the time and didn’t do my research.
